1 - 4 of 4 Posts
Will this work to add 2 inlet pressure gages on pump to meassure upper and lower pump inlet pressures and check loader input
I am ordering from McMaster.com
4003K712
Stainless Steel-Case Gauge +/-2% Accuracy 2-1/2" Dial, 1/4" NPT Male Center Back, 0-60 PSI
today$20.36 each40.722ft.
5112K62
Extra-Flex Nylon Tubing .106" ID, 5/32" OD,.025" Wall Thk, Semi-Clear White
today.25 ft.12.503each
51495K269
Nckl-Pltd Brass Push-to-Connect Tube Fitting Adapter for 5/32" Tube OD X 1/4" NPT Female Pipe
today5.48 each10.964each
51495K212
Nckl-Pltd Brass Push-to-Connect Tube Fitting Swvl 90 Deg Elbow for 5/32" Tube OD X 1/8" NPT Male
today2.95 each5.905
Discussion Starter #2
bump
Impeachment!
looks like the same stuff I used for my taps. Except the gauge. Is it liquid filled? I used an Autometer.
You gonna get 2 gauges or use a 3way valve and 1 gauge?
I just figured 2 gauges then I can monitor upper and lower at the same time
Thanks for the reply
1 - 4 of 4 Posts
