1 - 20 of 24 Posts
Ok Guy's,I know this topic has been beat in to the ground,but I see no info on this site.So let's talk about building a Wiring Harness.
All the threads on this subject were on Hot Boat and I do'nt know if We will ever get them back.
I am getting ready to start building My wiring for my boat,and I would appreciate any Pictures,diagrams and information that anyone can provide.
What are the acceptable wire gauges.I can get 12 guage wire ,in all the colors ,for free. Is it Ok to use 12g instead of 16g,for most of the wires.
The gauges that I will be running will be Autometer.
I will have a Tac,Speedo,Fuel,Oil,Temp,Volt.
I know over on the other site,I have seen color lists and some Good wiring diagram's.I need to know all the colors ,and gauge wire ,that I will need.
Thank's in advance for the help.....Hal
B.A.M aka "Black Azz Mike
12 guage is a little on the overkill side EXCEPT for power,starter and ground. I am using 12 guage on my g-wing. I am going to be running 10 guage for power,starter and ground. I have gotten away with running 16 guage for senders but I dont want any issues.
Well the thing is I can get all the 12g and heavier wire that I want,for free,and in my case free is good. We just do not have the 16g or lighter gauge wire available, in very many colors....H
Hey Rex, thanks .Thats what I,m looking for.
Cobra1,the boat is an 18' jet.but I am going to build one My self,as per My budget.....Hal
I ran #14 for everything except the power and the ground to the dash. There I used #10. I also put a 30 amp breaker in the hot wire back at the motor between the battery and the dash power wire. I did have problems with a couple of the colors and improvised there.
Hey Hal, I've called you acouple times. Call me back. Pat
Discussion Starter #12
Hey 396,I know I have seen pics of You'r wiring project.would You mind posting some of them here?...H
Do I need any thing else besides what are in these diagrams?...H
I'm No Expert
When i did mine i bought a few MSD wether tight connections. between the dash and motor i have two 4 pin connectors. One of them has all the senders running through it (oil pres, oil temp, water temp, rpm) the other has bildge, fuel pump, starter, msd ign. I then have my main ground and main lead that run to the dash which seperate. Whats nice is that i can pull those connectors and pretty much pull the motor leaving all the senders hooked up. I also purchased two 2pin connectors... One right at the fuel pump connection and one right at the bildge connection. I think i used #14 for just about everything, i want to say i used #12 for my bilge. I ran #8 up to dash, alittle over kill but they where out of #10.
Dont crimp your connections! Soilder everything, takes more time but is well worth it in the long run.
Here we go hope this works,I can't seem to get the pic posting to work...H
Discussion Starter #16
Shaun,Do You have any pics of You'r wiring?...H
I can post them BUT I am rewiring it tomorrow. i will post pics by sunday of the wiring for ya. What do you need help with bud? I can assist you with whatever you need. I am also going to be making a few extras this weekend. let me know if you are interested in one.
Spitter
I use my own colors and dont follow the diagrams. I just keep a wiring log of everything I wire.
Discussion Starter #19
Hey 396 ,Thank's. I am looking for pics of a typical jet boat wiring,under dash layout, terminal and fuse block placements and wire routing and conections. Also a clean engine harness layout.
I want to atempt to build a harness Myself,so I will know how to do it,as I try to do every thing I can Myself.You know what they say,Experiance is the best teacher.
any way I know there use to be a ton of pics of wiring on HB,You'rs and Roostwears Stevens project,were some good examples.....Hal
My last two boats I used a trailer loom. It has one#10 and six #12. Everything is inside of a rubber? sheath.
1 - 20 of 24 Posts
