Some guy
Anybody have a couple of these fittings in their box? Mine have been hogged out and kinda corroded. Would like to have some std ones.
Is there a reducer inside that, or is it just a standard off the shelf AN to AN fitting that you can buy anywhere that has AN fittings?
It is just a flair fitting, even if it was tapped for restrictor, still only a standard off the shelf -8 flair coupling
Sent from my VS980 4G using Tapatalk
Nah
It's a 3/8 ID hole on one end and looks like about 1/8 ID on the other.
Yeah, it's just a restrictor fitting. You can buy a standard fitting and tap out for restrictor. I'm not sure if those you have are produced anymore.
