Polished or dull finned alum BBC, any brand but with water pump flange so a magnaflow pump will bolt up. Thanks
IMCO makes a beautiful piece, with the added benefit that your water inlets are separate, so you can use some stainless ones that won't corrode.Polished or dull finned alum BBC, any brand but with water pump flange so a magnaflow pump will bolt up. Thanks
CIMCO makes a beautiful piece, with the added benefit that your water inlets are separate, so you can use some stainless ones that won't corrode.
Glenwood is out of production, but costs less money if you can find one. The water inlets are built in so the aluminum will corrode at some point.
Maybe check with Dave Connelly in Havasu, or CP Performance.
check out my postIMCO makes a beautiful piece, with the added benefit that your water inlets are separate, so you can use some stainless ones that won't corrode.
C
check out my post
I HAVE ONE 760 214 5476 $400Polished or dull finned alum BBC, any brand but with water pump flange so a magnaflow pump will bolt up. Thanks
