looking for a decent used oil cooler, doesn't have to be polished or chromed as long as its in great shape internally and works!
yeah, we 1/2 filled the twin turbo 496's block and need some help bringin the oil temp down noware you looking for the type that goes in the water line? looks like a long tube with the little tubes inside of it.
i have a couple of them. i will take some pictures and send them to you.
yeah, we 1/2 filled the twin turbo 496's block and need some help bringin the oil temp down nowsphss
don't know but with a 1/2 filled block and twin turbos, i'm sure it gets up there pretty quik.Tom : that is how my block is , 1/2 filled .. , what oil temp are you running ?
you got that and the valvetrain heat all built up in the oil pan and no way to cool down on this 1/2 filled block. this tt496 is punishing the shortblockI just took my Heat gun with me and shot it at the pan after I made those 10 passes , I still check from time to time like this . I even installed a oil temp sending unit in the pan and never hooked it up .
With the turbo's on it , it wouldn't hurt to get a cooler on it then .
It just how hard the bottom end of the engine is working , that creates that heat in the pan I think ??
[email protected]send me a e-mail and i will send the pictures. how do you measure the cooler? overall length off it?
