I have an electronic fuel switcher but I want to run both tanks at the same time. Does anyone have a valve for sale or know where I can get one thats not stupid expensive?
Thanks
i run each tank into a T & then out to the fuel pump...got the T at the hardware store :)...also...i have a fuel filter in each tank line before the T & 1 filter after the T & 1 filter after the pump to the carbs :)...just sayin'
FastRat
What kind of valve are you looking for? If you wnat to draw from both tanks at the same time, use a T fitting as suggested. If you want to draw from one tank at a time, there are several options. Depending on your fuel needs, i.t. big horse power, return needed, etc., the options range from not too expensive to several hundred dollars.
Whatcha need?
IMO not a good idea to pull from both tanks, if one tank empties faster than the other, when it gets low it will draw air into the system, I would stick with the valve you have, but thats my opinion
Well the problem is that I installed a Rex Switch panel but the switches provided wont work to switch the gauge and the valve which is just dangling right now. I have one bad sender also so I figured if I draw from both tanks and run the gauge on the tank that actually works I wont have to buy a new sender or drill a new hole for my toggle. Has anyone else had experience pulling air from an empty tank?
i have had my tanks in my boat since '73 (2- 12 1/2 gal) & have never had a bit of trouble with air in the lines...i have equal length hose from each tank to the T & then forward to the mech pump...it works for me! :)...just sayin'
FastRat
FastRat
I have had this problem, with equal length hoses, if your runnin big HP why take the chance of leanin it out
