1 - 20 of 72 Posts
Long story short, about 6-7 year's ago we did a grading job for a guy. We finished about a week ahead of schedule and he says "Hey I want to give this to you for a tip. You did a great job and finished a week ahead of schedule and since I'm moving in a month I don't want to worry about selling it. Don't ask me what's in it because I don't know I bought it off a guy about 2 year's ago"
I think it's pieces put together to make a decent engine, I want to sell it but haven't a clue what it might be worth: :)bulb:)bulb
I just pulled a head off of it today and dropped the pan so I could figure out what was in it.
It looks like the bore is 4.27" and the stroke is 3.76" = 430" (my best measurements)
The block has casting #'s 14015445 (4- bolt)
Heads casting #'s 3873858 ( Hi Perf cast in them. rect angle port)
Rods are H beam, look to be Eagle. They have ARP rod bolts that read; ARP Eagle 8740. The rods have a redish tent print 6.135 on one side of them.
Pistons are Arias, they have the # 41230 FH cast in them and have the # 291458 stamped on them.
And the crank has 20/20 from the machine shop. The casting numbers that I saw are GMT7 and 6223.
Crower roller rockers and a roller hydraulic cam (not sure of the cam maker)
All ARP fasteners.
Any thought on what something like this might be worth ???? :)bulb
I need to sell it so I can buy some more Ford parts.... or at least parts for the boat. :D
Thanks,
Sleeper CP
Jon
CANT RE MEMBER
Chvord
JON just put a front dizzy on it and i'll machine you up a set of adapters for the FORD valve covers!!.........
SERIOUSLY, what pan & intake on that (396)+..?:)bulb
None it came on the engine stand and with a shop bag on it. NO intake but it had a cheap chrome car type oil pan. It might add to the value ;)
Sleeper CP :D
CANT RE MEMBER
Looks Good
Sleeper CP :D
LOOKS LIKE DECENT PARTS IN THERE, LIKE CROWER ROCKERS, SOME OF THE BEST OUT THERE, BEARINGS HOLD UP IN THEM GREAT! SHOULD BE A NICE LITTLE MOTOR, I HAVE TWO SETTING IN THE SHOP LIKE THAT FOR SPARES FOR MY STREET RODS
Are You Kidding Me!!!!
I'm not sure do you not think it's worth anything ? :)bulb
I was just going to pull the roller rockers off of it and throw it in the metal scrap bin for savage when it was $300+ a ton, but SDPM thought it might be a good ideal to pull a head and pan off to see what was there.... ( Thanks Neil) :D
Sleeper CP :D
hey .. how much ?
Your Playin With Fire "Ford Boy"
You made me spit beer on my screen. ;) LoL that's funny.
I have a friend comming by tomorrow to see if he wants to buy it. I think he was looking for a 454 :mad: If he doesnt buy it he may give me some idea what to ask for it. I haven't a clue........ any thought's.
Sleeper CP :D
any idea on camshaft ?
it's a 427 rotating assembly in a 454 block.
probably for the 4 bolt mains.
any port work on the heads ?
if it had a flat tappet cam.. it could have been a spec built deal.
gray paint is a give away.they even masked the pan rails.
(traco used to paint sbc's like that.)
with a hydrolic roller, it is probably a street rod / corvette guy type deal.
all them parts added up cost some money.
i have no idea.
anywhere from a grand up to alot of couple grands ?
how much is your buddy offering ?
ball park.....a little less than a 460 but real close.
block is worth 400-500
pistons cost 400-900 depending on what they actually are.
rods around 450
heads 600-800 they are worth more unported.
crank..not much unless it is steel..200-250
cam setup around 500-600 new
rockers 250
that would work real nice in a 69 camaro with a tr and a richmond.
hey, your pulling our leg .....aren't you.
hey .. how much ?
Read the other post. It doesn't look to me like the heads have much if any porting, although I really didn't pay much attention to them. I have no idea on the cam spec's I just what to sell it.
I'll let you know tomorrow if he buys it from me.
No I'm not pulling you leg. We did a good job for the guy about 7 yrs. ago. It's been in our shop for that long, Neil (SDPM) told me to pull a head or drop the pan before I put it in the dumpster.. I'm glad I did ;) What the hell am I going to do with a Chevy.
Sleeper CP :D
cool deal
Casting #'s on a BB Chevy crank... where can I find them ?
Sleeper CP :D
Bostick Racing Engines
Sleeper CP :D
Whoa!
If I remember correctly it should be a 6223... been a while since I've seen that one... it's a crower hyd roller cam, but for the life of me cannot remember who it was for.
On the "number pad" in the front, what is stamped?
Discussion Starter #17
Whoa!
6223 it is.. Check your pm's.
Jon
here are some numbers for the crank..
BBC TWO PIECE REAR MAIN OIL SEALS
3.76" STROKE used on '65-'90 Mark IV 366T, 396, 402, 427 or 427T
6223.......396,402,427...forged, 1053 steel
7115.......396,402,427...forged, nitrided, cross-drilled, 5140 steel
3804816....396,402,427...cast
3856223....396...forged
3863114....402...
3863144....396,402...
3874874....396,402...
3879621....427...forged
3882841....396...forged, cross drilled, nitrided
3882842....427...forged, cross drilled, nitrided
3882847....
3882848....
3882849....427...forged
3887114....396...forged, nitrided, 5140 steel
3904815....396,402...cast, nodular iron
3941180....
3942411....
3965746..........semi finished, forged
3993804..........raw, 5140 steel
3863114....402...
3882847....
3882848....
3941180....
3942411....
I call bs on that list... 6223's came in 366 and 427 truck engines also!;)
Discussion Starter #20
Bostick what would your guess on the compression be?
Thanks for the PM info.
Jon
Sleeper Cp :D
1 - 20 of 72 Posts
