1 - 5 of 5 Posts
Urban Cougar Trapper
Which is easier , set motor on motor rails and bolt up Then drop whole assy into boat and once driveline angle is correct drill stringers and motor rails
OR
Mount rails with c-clamps to stringers and set motor in loose and jacking with it until everything lines up ? :confused:
I set mine on the rails clamped to stringers, measure measure measure then drill
OR
Drill rails, clamp rails to the stringers, align motor with pump using a rough cut/machined set of motor plates, then drill stringers. Build pillow blocks and finish motor plates once its all lined up perfect.
Already got custom motor plates and pads taken off old motor I'm reusing . Have to change motor location ...added longer rails , Jetaway . And LoPro intake
1 - 5 of 5 Posts
