1 - 7 of 7 Posts
· Registered
The antenna wire for my xm on the boat is about 10 feet long. Is it just a two conductor antenna that I could cut and shorten? What about splicing it to some kind of quick connector? I hate having 10' of wire spooled up on the dash. Anyone have any suggestions.
Thanks
da ninja
· Registered
Dont Do It
Thanks
da ninja
Do not cut asking for trouble that you will surely get.
Dont even tie up to tight move wire under dash.In most boats even anteena can be under dash.:D
· Boat Nut
gps / xm antennas
make sure the antenna faces up when mounted under the dash. Use heavy duty velco to hold it in place. cutting the cable asks for trouble, the recievers are sensitive to the db loss in the coax, and are tuned for a specific length. Many composite aircraft use this mounting technic with out issue. Carbon fiber will not pass a radio signal, so don't try to mount it under this material, fiberglass and wood are fine.
1 - 7 of 7 Posts
