1 - 14 of 14 Posts
8 New sleeves and 8 new pistons.
Been running the used stuff that was in it when we traded for it. Now that we know it is going to live this should fix us up through next season. Wonderful feeling tight pistons. :)
Boat Nut
Theres always a weak link.... All you can do is keep them minimised :thumb:
Discussion Starter · #5 ·
Driver
poor chevys and there bore spacing, so is it the same piston a prior then? you guys gonna make smokin?
Don't look like they have alot of compression. That's sweet! I learned compression is not your friend.
Discussion Starter · #8 ·
Same pistons as before. Seem to be working pretty well.
We will be in Choteau Marble Falls and Wheatland before SITC
Don't need much Patty. Have a hard enough time keeping it slowed down as it is. The cam is a baby also.
Driver
I wanna do the purcell money race and wheatland next year but with circle racing and a new daughter Momma needs convincing
Discussion Starter · #11 ·
We always loved the Purcell race. Just need to have another one some how.
Discussion Starter · #12 ·
Hope it all works out great for you guys Ron. Keep up the good work.
Thanks Hass. Those old pistons were so loose lol the rings hung out so far it would wear a step in them. Amazing a couple of them lived after opening up the pinched ring grooves on the lathe.
Pretty sure the learning curves have been straightened out.
I could see Dillon start the engine from the out ramp. Blue smoke signal.
1 - 14 of 14 Posts
