[SOLD] Chevy/ Buick Olds Pont. 200R4 trans Build stage 2 750 hp 650 tq
Closed Thread
    V-Drive 4 ever Billdoe's Avatar
    Greenwood , Calif
    Default Chevy/ Buick Olds Pont. 200R4 trans Build stage 2 750 hp 650 tq
    Have for sell the Transmission i had built for the Camaro. it is a Stage 2 , 200-R4 trans well here's the Info straight from his website....
    2004R-Extreme Automatics
    Stage 2 Build
    EA Super Pump
    Hardened Input Shaft
    Billet 6061 Aluminum Piston in Forward
    Billet anchor pin
    Tensioned Teflon sealing rings
    3 clutch OD
    Tested and sealed center support
    Race clearances
    EA Billet 300M Forward Drum Shaft
    7 clutch direct
    EA Billet Extreme Servo (Largest In the Industry)
    Roller Low Clutch Support
    HO Low Roller Clutch
    New OD Roller Clutch
    Hi Performance Calibrated Valve Body **BRC
    Lock up or Non Lock-up
    Governor Calibrated for approx. 4800-5200 RPM shifts
    $450 Lifetime Freshen up (Original Purchaser)
    1 Year Limited Warranty
    Price 2295.00
    Torque Converter 650.00
    Stall converter 2800-3000
    will sell for 1200.00 and if it ever needs to be rebuilt i can get it done for 450.00 since i purchased this in March/April.. this trans has maybe 2500-3500 miles on it..
    I ended up pulling the new engine and trans and had a 427 Small Block Built and bought a 5 speed manual trans is only reason im removing it from car..
    will sell trans separate from Converter since it is a High Stall Conv. 1000 for trans and 250.00 for converter or 120 for everything.. i will even include the TV cable , GM Bracket for intake to mount the cable and trans cross member and driveline Yoke
    Manwhore!!!!! Quick99's Avatar
    Fullerton, California, United States
    Damn pretty good deal. Always liked that trans when I worked for GM.
    Greenwood , Calif
    Quote Originally Posted by Quick99 View Post
    and the nice thing about this one is .. Lonnie Dyers at Extreme automatics is rated in the top builders for transmissions of this type.. that's how i found him by every website forum i went on everyone was complaining about transmissions breaking and going tho this guy and they haven't had an issue since.. nice trans just want the 5 speed Manual trans backed up by a 427 small block makin 650 hp
    Greenwood , Calif
    Sale Pending.. Meeting someone today for it...
Closed Thread
