[For Sale] 88 GMC Extended cab Dually With 93 Cummins 12 valve
Results 1 to 1 of 1
    Senior Member 65 Sanger 440's Avatar
    Sep 2009
    In the desert high on a hill!
    Default 88 GMC Extended cab Dually With 93 Cummins 12 valve
    Selling my 88 GMC Extended cab Dually, great tow vehicle.
    1988 GMC Extended cab dually. Has a 93 Cummins 5.9 motor and overdrive trans. Motor has 5x14 injectors, 4000 rpm governor spring, denny T stage 2 fuel pin and custom made turbo with 4" exhaust. Trans has had extra clutches added, shift kit, and 2 oil coolers. The body has damage on driver rear fender,(will throw in another fender) and chips in the paint. Interior is in decent shape with a wear spot on the driver seat. New front brakes and rotors done last year. Truck has been lowered 2 inches. Truck has 213xxx miles and Motor has 165xxx Trans has 80xxx. I have been driving this for the past 4 years with the conversion and it is great. The AC works and is all there, the Cruise control and Speedometer do not work because the pulse count are different between the Dodge and Chevy. I was going to put in a GPS speedometer just never got around to it, as i just used a GPS app on my phone. cost of parts for the gps speedo is 260.00. More pics on request.
ID:	969306   Click image for larger version.
ID:	969314   Click image for larger version.
ID:	969322   Click image for larger version.
ID:	969330   Click image for larger version.
    “If we ever forget that we're one nation under GOD, then we will be a nation gone under.”
    -Ronald Reagan
