1969 sanger true flat
Results 1 to 7 of 7
    Jul 2012
    oscoda
    Default 1969 sanger true flat
    i would like to find out how to get bushings for the struts and prop shaft it has little slop in the shaft also i am a new onwer of v drives so would like to figure it out with some help please and thanks
    Upstanding Member Sharp Shooter's Avatar
    The Parking lot
    Quote Originally Posted by davidthomas View Post
    Rex Marine
    Senior Member bville's Avatar
    Sep 2009
    Glasgow, KY
    Glenwood marine also has what you need.
    I like the nylatron or delrin type I got from Dan at canyon marine. Goes by Liquid Dan here on the boards. He has always answered my dumb questions with patience. Also, here is an easy tip for installing the strut bearing. Take a length of all thread with large washers thru bushing then thru the strut and thru the other half of the bushing .Put nuts on each end of the all thread and tighen them down pushing the bearings into the strut.
    armandshammer
    Senior Member CampbellCarl's Avatar
    Whittier, CA & Katherine Landing
    Good advice there. Might wanna let the OP know how to get the old ones out first. I use a hacksaw blade and GENTLY cut through the old bushing. Then fold one side toward the other and it should slide out.
    CC
    Oh wait, some smart ass is gonna come here and say that I jumped a step.......pull the rudder and prop shaft first. May as well reseal the rudder shaft and prop shaft as long as they're out!
    Originally Posted by Rattle Can Lou
    Again, if I came across as a v-drive snob..I apologize,
    Mike
    Senior Member JAFO's Avatar
    Buena Park, CA
    Quote Originally Posted by Desperado View Post
    X's 2 with Dan's products. I've bought a few parts from him. They fit right, good quality, fair prices.
    Dan Aaseth
    Canyon Marine
    661.510.6362
    Senior Member 66sanger's Avatar
    Jul 2012
    Okinawa, Japan
    Default strut bearing
    Jim Wilkes at Wilkes Marine talked me through this over the phone the first time I did it, 10 years ago. He helped me measure it correctly, sent me a Nylatron bearing, and talked me through removing me prop shaft. I cut the old one with a hacksaw blade like Carl said, and gently drove the new one in with a wood block and hammer before cutting to length. It's still in my boat and works great!
    Eric Armstrong
