[Question] rb water pump clearance
    Default rb water pump clearance
    Can the relief cut be increased enough to clear an eight inch crank trigger wheel?
    armandshammer
    Senior Member Pm/pe122's Avatar
    Oct 2010
    not on an original river rat pump , it will expose the o-ring and cause it to leak , i tried and took it down to the oring and still would not fit . ended up with an extention from good vibes for about a hundy or so , im not 100 % on the RB deal but would imagine the same outcome .
    Senior Member WES...'s Avatar
    Default yep
    stand off is the only way to go
    HOUSE OF FLATS LANDLORD
    thanks for the info. It came with the extension, ill just have to figure out exactly how it goes together. I know we had to use some shims when originally installed, but will definately give it a shot. Great pump glad I didnt ruin it
    armandshammer
