Cav Plate Geometry
Results 1 to 7 of 7
Cav Plate Geometry
    Senior Member 500BBC's Avatar
    CIUDAD MEXICO NORTE
    Default Cav Plate Geometry
    I'm redoing my plates. Currently have the old Hallcraft hexbar setup and will be installing a 1" control bar.
    How do I determine control arm length and turnbuckle angle?
    19' Schiada,, blown/injected.
    "Pot had helped, and booze; maybe a little blow when you could afford it. Not smack, though" President Barack Obama.
    Liberals just chose to ignore relevant information about the world they live in, and then call themselves sophisticated for having chosen to be more stupid than God made them.
    Already miss the 310/562 2manymustangs's Avatar
    Quote Originally Posted by 500BBC View Post
    Before you start adjusting besure to lubricate the threads really well with fishing reel oil... Im sure you know where to find some...
    Sorry, I have nothing else to add... I think everyone that can answer your quesiton is en route to Long Beach/Marine Stadium...
    Pat Eason, the voice of reason...
    CIUDAD MEXICO NORTE
    Quote Originally Posted by 2manymustangs View Post
    While you're there go to the GN pit, measure and photograph everyone's set up and let me know the specs.
    I lube all my junk with rendered tuna heads BTW.
    Jun 2010
    Don't you need a decent battery for those plates to work Brad??? See you in Sept.
    CIUDAD MEXICO NORTE
    Quote Originally Posted by 77Mandella View Post
    NICE!
    Smart ass, Marko actually responded with hopefully, a cure. I'm agonna try and get it right before Sept.
    Gina's coming too with William so her and Leslie are in charge of us nitwits.
    Brother, if I was there I surely would...
    10-4 on the tuna grease, make sure it is sushi grade though...
    Jun 2010
    NICE!
    Let me know if I can help with anything.
    Good to know someone will be in charge, those wild charging burros at midnight can be dangerous
    Jeb
