Bearing P/N for Casale Rebuild
Results 1 to 8 of 8
    Default Bearing P/N for Casale Rebuild
    I decided to pull my v-drive this winter and open it up for a overdue inspection. Got it apart yesterday and actually looks pretty good inside. I think I am going to replace the bearings/seals while it is out. I have been talking to the local bearing supplier and struggling to find a Part number for the large double row ball bearing (thrust bearing?). Also, a little confusion on the top bearing with the puller groove. They come up with a slightly different part number than what my current one shows. Anyone have a list of the bearing P/Ns? This is a split case.
    Here is what I found to date
    2 bearings P/N 6207 C3
    1 bearing marked 6306 C3 ORS RS1 Turkey (this is the one with the puller groove and has one side sealed)
    1 bearing marked 6306 C3 (no puller groove or seals)
    1 bearing no markings Double row ball bearing dimensions OD – 2.835”, ID- 1.375”, width- 1.062” P/N ?????
    1 seal NS 50151S USA
    1 seal National 472258
    Any info appreciated.
    Chuck
    Placentia, CA
    The double row is a 5207. 6306N is upper with snap ring groove. The 6207 is the upper input bearing, should only need one if the bottom output is a double row.
    All the bs after the bearing number determines sealed, non sealed, rubber seal, metal seal etc., which can be popped off.
    Call me with questions, I stock all bearings and seals also.
    Steve Peterson 714 579-7857
    steveo143 AKA DiMarco 21 II
    Thanks for the info. That is what I needed.
    The second 6207 is in the small housing (in/out housing, which I don't have have an in/out, just the housing). Does that make sense? The only sealed bearing I had was the one with the snap ring groove. It had a rubber/plastic seal on the outside face (cap side). Is that correct? I question because whoever built this had the snap ring groove 6306 installed on the bottom shaft (with groove buried in the case). Was kind of a pain pulling the upper without the groove.
    Would you post or PM what a complete set of bearings and seals (5 bearings, 2 seals) would cost shipped to 34997? That way I can avoid the hassel of dealing with the bearing shop. I have a gasket set, but would be interested in a another also (I like to keep a spare). I assumed that the shipping costs would be a deal breaker, but maybe not.
    Much appreciated.
    Placentia, CA
    Makes sense to me, you have what is known as a direct drive with a 5207 and 6207 in the output housing. PM coming soon.
    Thanks again Steve. Is that snap ring bearing suppose to have a seal on one side?
    Senior Member the bandit's Avatar
    YOUR IN GOOD HANDS WITH STEVEO!
    I got my v-drive overhaul almost done but had a few questions:
    Should I use a thread sealant on the bolts that hold the bearing caps on?
    If I calculate the amount of gasket/shim needed for a bearing cap to be .007" do I use one .005" shim or two? What about if it comes out at .008" (round up or down)?
    Both gasket kits I bought don't have a gasket for the 6 bolt flange on the output housing to case. Where do I get one for that? It did have a 5 bolt gasket that is pretty close. I could just punch two new holes in those.
    Again, thanks for any input
    Chuck
    Placentia, CA
    Quote Originally Posted by flspectra View Post
    Chuck
    I use thread sealant on all bearing cap bolts and lockwashers.
    Round up.
    You can add the 2 holes or you can buy some 6 hole gaskets from me.
