help needed- Lenco crank button
Results 1 to 12 of 12
    Can you prove it cabron? TSR2626's Avatar
    Jul 2012
    Northern IL/Mohave County AZ
    Default help needed- Lenco crank button
    I am mating a Lenco clutch to the engine for my hondo and have run into an issue with attaching the crank button. the button bottoms out against the end of the crank and it is about .325" from the flexplate. the only spacers/shims I found are only around .030" Anybody had this issue?
    If you run a flexplate you need to machine a 1/2" spacer. Most flywheels take up the space adequately.
    Jul 2012
    Ok that's what I figured. I was hoping someone sells them or had one laying around. Are there benefits to running a flywheel instead of a flexplate? I just went for the flexplate because of the less weight and less $$
    Jul 2012
    Did a search on here and found lots of good info on the flexplate vs flywheel. Lots of informative posts on the subject from GN7. Rest in peace Bob
    Jan 2012
    lake Charles, Louisiana
    Lenco sells em, spacers
    Jul 2012
    Quote Originally Posted by SHAWN DAVIS View Post
    thanks. I'll give them a call
    Jun 2014
    I just got the button and spacer a few months back, think the spacer was $20
    Jul 2012
    Quote Originally Posted by ERV JR View Post
    Thanks that's less than I expected. Small things sure add up towards the end of a build.
    Jun 2014
    Well i call ordered the button then.they.threw that cool little fact in . Oh u need a spacer
    Jan 2012
    Funny, I ordered a complete funnycar driveline from them, came without the clamps for the coupler, got the same response...
    Jul 2012
    also found this through speedway motors. looks like it eliminates the need for the separate spacer. $60
    Take the heavy flywheel and clutch out of your stock Chevy with this "cheater" button. Pick up approximately 50 horsepower through this direct hook-up. Weighs only 2.3 lbs. Made of heavy duty steel.
    1-3/8"-10 spline fits Brinn & Bert transmissions.
    Item Details
    1-3/8"-10 Spline
    (won't fit Chevy shaft)
    Specs Material Type:
    Steel
    Weight:
    2.30
    Sold in Quantity:
    Each
    Overall Thickness:
    1.25
    Finish:
    Natural
    Overall Diameter:
    4.50
    Spline OD:
    1.38
    Spline Count:
    10
    Jun 2014
    that's only good if you have a 10 spline , most the stuff is now 16 or 32
