Solid splined driveshaft question
Results 1 to 6 of 6
    Senior Member poncho's Avatar
    SE Mass/Bering Sea
    Default Solid splined driveshaft question
    New motor is in and aligned the motor and v-drive today, when setting the shaft with the lock collars should i tighten everything up or allow the shaft some play, say an 1/8th of an inch.
    Kent, WA
    We leave about 3/16" or so "slop"
    SE Mass/Bering Sea
    Thank you, couldn't wrap my mind around tight.
    Sent from my SM-G900V using Tapatalk
    Senior Member liquid addiction's Avatar
    carson city nv
    X2. I was taught to also put a little grease on the splines. It will rattle at idle but that is normal.
    Kent, WA
    Quote Originally Posted by liquid addiction View Post
    Yes, we use the Extreme pressure grease. This set up has been in the boat since 2003, still has the black oxide coating on the splines !
    SE Mass/Bering Sea
    I used EP wheel bearing grease, this new motor has a larger cam so it idles higher, you could hear it pretty good with the old one.
