Good thing to check
Results 1 to 9 of 9
Good thing to check
    Senior Member Sangerboy's Avatar
    Moorpark and Loma Linda CA
    Default Good thing to check
    it's good to check your Magnaflow water pump every few years, I noticed a little water coming from the weep hole so I thought I'd get into it and check it out. Good thing
    as the bearing on the engine side was almost frozen and the bearing on the impeller side was…… well as you can see, basically destroyed. Thanks to Mike at Rex Marine who had fixed me up with a rebuild kit
    http://www.performanceboats.com//signaturepics/sigpic415_1.gif
    Senior Member Mr. Denton's Avatar
    Jun 2014
    Ever have oil leak from yours?
    “Some people spend an entire lifetime wondering if they made a difference in the world. The US military doesn’t have that problem.”
    Using Tapatalk
    No, i've never had oil leak out, that would seem to indicate that the engine side bearing would be a bit loose as it would be the only thing to prevent oil coming in from the engine. The impeller side has seals in addition to the bearing to keep water from coming in.
    The Earth
    Blog Entries
    24
    Yep check em... that one looked pretty nasty.
    Late Start-er JusTrouble's Avatar
    Aug 2013
    Central Valley (Clovis) CA
    Nasty! How long did that unit last?
    Good to hear you are still around stranger
    JT
    I dont NO much.
    I would rather have it and not need it than need it and not have it.
    Favorite fortune cookie: Character is who you are when no one is watching.
    Quote Originally Posted by JusTrouble View Post
    JT
    Sadly JT I think it only lasted 15 or 20 years :roll eyes:, I'll have to go back and check when I first put that motor together a long time ago, motor has seen several iterations but the pump was always constant
    Default There that's better
    Senior Member Mr. Travels's Avatar
    Oct 2013
    Fontana, CA
    Default new to forum
    This is reverse427 (Sparky). Boat with old name Bit o HoneyClick image for larger version.
    Jun 2014
    Is that Greg Snow's boat? Looks awesome!
    Using Tapatalk
