Horn Placement
Results 1 to 5 of 5
Horn Placement
    Member Travesty's Avatar
    Jul 2012
    Portage, Michigan
    Default Horn Placement
    Was stopped this weekend for a basic safety check. The horn I have is just a small hand held air horn that I can access. I was wondering what other people are using in their flats. Do most use a small air horn, or do some actually have a horn button mounted somewhere?
    Jun 2010
    I use a coaches whistle never been a problem
    Sep 2009
    Walled Lake, Michigan
    Default horn
    I have one of the pressurized can horns. I never knew a manual whistle would be legal. Cheaper and doesn't run out of air. My problem is the kids want to play with the can air horn. Both annoying and a problem if it is out of air when you are stopped. And of course they don't bother to tell me when it's out.
    Darin
    Margaret Thatcher once said The trouble with socialism is that eventually you run out of other people's money.
    S&S
    S&S is offline
    Steve S&S's Avatar
    May 2011
    Granite Bay, Ca
    Get a small whistle from Wally World for $3, I've been stopped and told they are legal to use. I had a hand held canned air horn literally blow up in the side compartment of a boat once. Sitting in the sun for too long on a hot day. Didn't hurt the hull, blew the compartment wood loose off side of boat.
    Learning to drive,, One change of shorts at a time...
    Late Start-er JusTrouble's Avatar
    Aug 2013
    Central Valley (Clovis) CA
    Default Obnoxious
    I figure that the purpose of having an audible attention getter is just that - for what ever reason. We have always used the air can and everyone knows how well the sound travels from these deals. A whistle may pass inspection but you would turn blue trying to get another boat to hear you, let alone someone on shore from the middle of the lake. I recently found the Ooouuuga horn I had purchased to secretly replace the original horn on my wife's car. Just thought it would be funny as hell the first time she hit it. Couldnt find a good place to mount it so it was on the shelf. Just to be obnoxious, I mounted it up under the deck of my flat since it has a way of amplifying every other noise produced by the boat. It is soooo loud, that it will work really well at displacing un-expecting passengers. However, this weekend I tested it out on the water and it didnt work near as well as I expected it to at a distance. I still think it is funny as hell, but I will continue to depend on the air horn and have this electrical option as a backup. Oh, and I mounted the toggle switch under my leg on the front bench seat support next to the bilge pump switch. (The extra wires will be used for the kill switch I just got from Rex)
ID:	778722   Click image for larger version.
    I dont NO much.
    I would rather have it and not need it than need it and not have it.
    Favorite fortune cookie: Character is who you are when no one is watching.
