[Question] 1972 sanger rebuild
Results 1 to 6 of 6
1972 sanger rebuild
    Aug 2015
    Orange CA
    Default 1972 sanger rebuild
    I am rebuilding a '72 Sanger bubble deck. the prop strut delaminated the floor. I have the floor fixed and I am in the process of re-rigging. I need some idea's on how to make a return spring set up for the down pedal?
    Senior Member Sanger-Spectra's Avatar
    May 2010
    Do you have the over ride pedal already or are you looking to add the over ride? if you have the peal already then the single spring return set up is pretty simple, spring and a dead man and there you have it. f you don't have the pedal you need to by the over ride set up first. Here is a picture of a spring et up I just put in my Day Cruiser, the springs came from Glenwood Marine.
ID:	832145   Click image for larger version.
ID:	832153   Click image for larger version.
ID:	832161   Click image for larger version.
ID:	832169   Click image for larger version.
    ptc
    ptc is offline
    Senior Member ptc's Avatar
    Oct 2010
    Sacramento Area
    Here is my Up/Down pedal spring setup. Mine has the typical Finishline lockout handle with override when you hit the pedal(s). That center plate is just a guide so the rod doesnt bow.
ID:	832217   Click image for larger version.
ID:	832225   Click image for larger version.
ID:	832233   Click image for larger version.
    Aug 2015
    Orange CA
    I have the overide pedal installed. should i use 1 spring or 2? the boat will be used for recreation on Parker strip
    Senior Member dryhoze1's Avatar
    Sep 2009
    San Juan Capistrano / San Clemente, CA
    Quote Originally Posted by blown money View Post
    I think one would be fine
    Bergeron has a nice single set up deal
    Aug 2015
    Orange CA
    thanks for the pics and the info. very helpfull!!!
