This Ol Barge
Results 1 to 14 of 68
This Ol Barge
    Senior Member Eliminator21vdrive's Avatar
    Jun 2011
    Diamond Springs, California, United States
    Default This Ol Barge
    Well I hate to see the old girl go but the gel wont polish back and I never liked red.
ID:	900289   Click image for larger version.
    Jun 2011
    So I replaced her with this
ID:	900305   Click image for larger version.
ID:	900313   Click image for larger version.
ID:	900321   Click image for larger version.
    Jun 2011
    Tear down time and see what I have.
ID:	900353   Click image for larger version.
ID:	900361   Click image for larger version.
ID:	900369   Click image for larger version.
ID:	900377   Click image for larger version.
ID:	900337   Click image for larger version.
    Jun 2011
    Fresh built engine that got water in it luckily i have a few extra blocks and freshened one up to sell original motor. I am replacing floors this weekend and am looking for material recommendations. They used lag bolts directly to the top of stringers luckily no major damage to them!
    So the plan:
    Just ordered Callis crank and rods 4.25 6.385 SRP 10.25:1 to make 496, have Edelbrock marine heads going to call Clay Smith for one of those magic hydraulic roller cams.
    Hope to make 600+
    Want a 75 mph safe cruiser, if / when I go over that ?
    I have a banks twin that I would like to go to efi at a later date, I love period correct stuff.
    What I need.
    Change cavitation plate actuator to under the floor.
    Need to upgrade actuator shaft to 7/8 and new pillow blocks.(What material?)
    What width cav plates?
    How long on eye levers?
    Need help with center cav plate?
    Have some sexy swim step mounts and step/teak to set rid of the crap on there.
    want to keep engine in the 6k range have 16's need prop rec. and gear rec.
    Keeping original interior for this season.
    Trailer getting new boots and some westerns but wait to paint this winter.
    Jun 2011
    What are the thoughts on single cable steering? I have A calgo and all the parts in first boat to swap?
    What hull is that, Spectra ?
    Just noticed, the dash doesn't look like a Spectra.
    Jun 2011
    Eliminator. By the way thanks Bildoe for the hook op other than the DMV debacle.
    Jun 2011
    Default Really no responses?
    So the plan:
    Hope to make 600+
    What I need.
    Jun 2011
    I have always liked the double step deck even if they are not the best performing boat out there!
ID:	900730   Click image for larger version.
ID:	900738   Click image for larger version.
    Senior Member usual suspect's Avatar
    Apr 2009
    So. Cal
    Nice Cruiser. Just for safety and performance, I would put the calgo steering in it and use a clam shell on the rudder post. Way better than a push-pull cable set up, particularly for vdrive. I would also try to keep the batteries away from the bilge area and away from the vdrive if possible. Good luck with the build!
    Jun 2011
    Quote Originally Posted by usual suspect View Post
    Re, batteries? Move to where? Weight ? I can put under jump seat at transom.
    Jun 2011
    Anybody want to chime in on the center cavitation plate?
    Apr 2009
    So. Cal
    Quote Originally Posted by Eliminator21vdrive View Post
    With a bigger boat, I definitely would move the weight back to the rear of the boat if possible. The batteries at the rear transom make a lot of sense to me, and it will get them out of the Vdrive gear box area.
    Jun 2011
    Default Update
    So a little slow going at the moment, work kicking my ass but have boxes of new parts/bling showing up and all of my material/rigging here now. Time to get some work done!
    Changing steering to calgo, new cav plate set up/pillow blocks /center cave plate stainless plates. new gauges bezels and spun up a steering column bezel on the lathe.
    The swim step brackets were an abortion so replace everything!
ID:	906649   Click image for larger version.
ID:	906657   Click image for larger version.
ID:	906665   Click image for larger version.
ID:	906673   Click image for larger version.
ID:	906689   Click image for larger version.
ID:	906697   Click image for larger version.
ID:	906705   Click image for larger version.
ID:	906713   Click image for larger version.
ID:	906729   Click image for larger version.
ID:	906737   Click image for larger version.
