Samantha,s Biesemeyer Build
Page 1 of 12 1 2 3 4 11 ... LastLast
Results 1 to 14 of 160
    Manage MacTilley Racing Dry docked's Avatar
    Feb 2013
    Valley Center ca.
    Default Samantha,s Biesemeyer Build
    As most of you know, Samantha,s Mandela was totaled last August at Long Beach. Before we made it home some wonderful people in the boat racing community donated funds towards a new boat. (As soon as I get permission I will share)
    With the help and advice from other racers we are planning to debut this project at Parker for the spring race.
    So now the work begins. Bottom pictures are as we brought the boat home.
ID:	1028081 Click image for larger version.
ID:	1028083 Click image for larger version.
ID:	1028085 Click image for larger version.
    1986 Daytona sprint boat SE-155
    Feb 2013
    Valley Center ca.
    Default The work begins
    Once the boat was flipped we found one side of the ride plate area was more than 1/4 lower than the other. With the advice from other racers we set a plan as to exactly how we wanted the bottom to be. The next phase is lots of sanding and filling.
ID:	1028097 Click image for larger version.
ID:	1028089 Click image for larger version.
ID:	1028091 Click image for larger version.
ID:	1028093 Click image for larger version.
    Very cool!!!!
    Old Timer LeE ss13's Avatar
    San Dimas CA
    Is that Jim Lawrence's SS 56?
    I don't know what I don't know because I forgot !!!
    Quote Originally Posted by Freedom Child View Post
    They all look alike upside down
    Quote Originally Posted by Wannabe View Post
    A grace of the English language that you obtain simply supersedes all reasonable expectations.
    Feb 2013
    Valley Center ca.
    Quote Originally Posted by LeE ss13 View Post
    I believe it was, last owner to actually use it was Eric Sperry.
    Dave
    Peoria, AZ
    If so, not his current boat.
    Paul
    Feb 2013
    Valley Center ca.
    Quote Originally Posted by dekman View Post
    Very cool!!!!
    Thanks Bob, you going to be at Parker Thanksgiving?
    Feb 2013
    Valley Center ca.
    Paul
    Prior to Eric, I am not real clear of its history. Here is a photo of the same boat with an earlier paint scheme. Maybe you guys can help us.
    Feb 2018
    I'm stoked to see this boat on the water. Samantha is a good driver, and it will be great to see her in a more competitive hull. Good luck guys! See you at Burley, if not before.
    Kip
    Quote Originally Posted by Dry docked View Post
    Hopeful if I can get her back together... :-)
    Feb 2013
    Valley Center ca.
    Quote Originally Posted by washedupkip View Post
    Kip
    Hi Kip
    We had more fun with the Mandela than we ever imagined we would. Samantha is maturing into a very competitive driver, she is definitely ready for the upgrade. She has driven my boat during testing, she is very familiar with the difference.
    I see you are doing some repairs to your boat. Good luck to ya, see you soon.
    Dave
    Feb 2013
    Valley Center ca.
    I am sure you will
    Feb 2013
    Valley Center ca.
    We filled and sanded so the dead rise at the strut is just a little over an inch, perfectly even both sides. The rocker is now 1/2 even on both sides, with a 14 ride plate area. Lots of glass work with very little filler.
ID:	1028187 Click image for larger version.
ID:	1028189 Click image for larger version.
    San Dimas CA
    How would a B-Boat ride if it had no rocker? And how would it ride if it had 1" of rocker? Does it just effect the straight away handling or does it change turning also?
    Thanks, Larry.
