Sanger Drag Hydro Questions
Results 1 to 14 of 15
    Newbie
    Sep 2010
    Default Sanger Drag Hydro Questions
    Hi all, I have a Sanger Drag Hydro I'm putting together after a few years of sitting and need some help from you experts. Have owned a couple v drives in the past but never
    a Hydro w Lenco, and have never done the engine to V drive alignment or proper placement setup from transom. I'm a newbie at this and any help would be appreciated.
    Hoping to get this on the water this year. Can and will provide any details needed.
    1. Is there a thread or written procedure on engine v drive alignment someone can point me to ? Tips ?
    2. Can anyone tell me how to decode the Hull ID # branded into the stringer ? SL-xxx-72
    clueless Sangerskier's Avatar
    Aug 2017
    Fallon, Nv.
    Hull# SL I believe is super light, 72 would be the year and the 3 digits in the middle the numerical sequence. There should not be any dashes in it I don't think. You say its branded into the stringer? As I understand it Sanger never, ever burned the hull numbers into the hull. Mine look like faded pencil under the resin and theyre not on the stringer but inside transom just to the right of rudder.
    Newbie
    Sep 2010
    Quote Originally Posted by Sangerskier View Post
    Sangerski
    I looked again and not branded but dark gray or black and very well could be pencil. Definitively on top of the stringer and under resin back by the transom.
    Any info out there on production numbers produced that year ?
    Senior Member SKIDDER's Avatar
    Aug 2010
    Chino Hills, southern California
    Default Branded or pencil
    My 72 circle Sanger has it burned in the transom with a dash???
    Aug 2017
    Fallon, Nv.
    Well there ya go, looks like I'm wrong again. I don't remember who told me that and I suppose there are allot of stories out there but Harlan Orrin would be the authority.
    May 2014
    Meadow Vista Ca. Huntington Beach Ca.
    Default drive line
    Are you going to run a drive line with U joints or a splined solid shaft or a greek coupler by its self?
    Newbie
    Sep 2010
    Quote Originally Posted by speedtrap View Post
    I will be using the greek coupler by itself.
    May 2014
    Quote Originally Posted by SangerV View Post
    Are your engine rails on the stringers angled as higher in the back and lower in the front? Or do they run true with the stringers.
    Some pictures would help.
    Mar 2014
    Are your engine rails on the stringers angled as higher in the back and lower in the front? Or do they run true with the stringers. <br>
    <br>
    <br>
    Newbie
    Sep 2010
    Stringers are angled from higher in the back to lower going forward. The Lenco bell housing has integrated stringer mount pillows which were not disturbed with this re power.
    Engine (BBC), Lenco, greek coupler drive train stayed the same. The problem is that I changed the front engine mount from (two piece mount & timing cover separate, to one piece motor mount incorporating timing cover ) which must be modified to length, to sit on top of stringer motor rails. Also I am concerned if the previous setup was a bit motor aft heavy. I am just not practiced in the tolerances necessary with greek coupler, and if any forward backward placement of the engine and/or modification of the length of coupler is indicated.
    Mar 2014
    Motor rails need to be the same angle (parallel)as the vdrive input shaft. Assuming a 10* vdrive and approx 8* strut, rails about 2-3* angle.
    Vic Esposito
    small block jet 2sangers's Avatar
    Lexington SC
    This is how we did ours. First pic with one safety collar is mockup. Later we learned the shafts should be spaced so a bolt can be installed in the hole, eliminating the need for safety collars. The biggest thing was getting everything perfect when running tight and still being able to slide the coupler by hand. In other words perfectly aligned. Sorry for the sideways pics
ID:	1032241   Click image for larger version.
    May 2014
    Quote Originally Posted by thefreak View Post
    Vic Esposito
    What Vic said.
    Newbie
    Sep 2010
    Quote Originally Posted by 2sangers View Post
    Thanks for your reply, have been away for a few days. When you say perfect do you have a tolerance number ? My coupler has a bolt. Will post more pics.
Similar Threads
  1. 78 sanger drag hydro
    By luv4hydros in forum Boats for Sale
    Last Post: 10-11-2009, 09:33 AM
  2. 77 ski sanger picklefork drag hydro
    By Mouzer in forum Boats for Sale
    Last Post: 10-19-2008, 10:08 AM
  3. Sanger Drag Hydro on Ebay
    By Sanger Picklefork in forum V-Drives
    Last Post: 05-18-2008, 06:50 PM
  4. sanger shovlenose drag hydro
    By Swamp Donkey in forum V-Drives
    Last Post: 03-09-2008, 11:34 PM
