Magnaflow water pump value?
Results 1 to 11 of 11
    Jun 2016
    Default Magnaflow water pump value?
    I have a Magnaflow 1" water pump that has never been installed or used. It's like brand new. How much is it worth? I'd like to get a few quotes and if there all around the same then I'll put it up for sale. Also have a Casale shift lever and a nice blue anodized 10 1/4" (end to end) passenger dash handle with finger grips. What's their approximate value? Thanks!
    Jun 2016
    Default ???
    Does't anybody have an idea what these items are worth? Sure would like to read an opinion. Thank you.
    Peoria, AZ
    Wild guess, $250.
    Paul
    Senior Member SPECTRA-SANGER's Avatar
    Sep 2016
    I was thinking that same number 225 to 250, if you have impeller, 250 not 225.
    Jun 2016
    Thank you guys!
    New ones are higher priced now, I would think $300 or so
    ptc
    ptc is offline
    Senior Member ptc's Avatar
    Oct 2010
    Sacramento Area
    CP Performance doesnt even have new ones for $399 with the extension on it.
    https://www.cpperformance.com/p-1293...ater-pump.aspx
    Yours in new condition would be probably $300 easy -
    Lookout I'm Crankin it Baby Rattle Can Lou's Avatar
    Boise, Idaho
    I'm with Barry...there are times of the year when you can't get these..So 300.00 would be the number in my mind but only if it truly looks new..if it's been shop worn..and chrome looks abused or scuffed your back in the 250.00 range..
    Quote Originally Posted by ptc View Post
    CP Performance only has 3/4" new ones for $399 with the extension on it.
    Yours in new condition would be probably $250-275
    I have a used one and I would ask probably $200 for with extension and cam drive and new impeller
    Hope that helps!
    Those are 1" pumps, you are confusing hose with impeller dimensions.
    Larry
    62 Bel-Air 409
    260 Eagle XP HP500EFI
    2016 Corvette Z51
    Remember in November
    Well done USN Seal Team 6
    Not confused about anything Larry, I noted it was 3/4" inlet and thats all CP has (or doesnt have in stock), they dont even sell the 1" inlet models. The impeller diameter is much bigger than 3/4" or 1" and actually in the 1" pump on my BBC 496 I had to cut off 4 of the 8 vains because it pumps too much water. With it like that, the engine runs water temp right at 185 or so....
    My junk is all sold - package deal.
    Well as I stated you are confusing pipe size with impeller size, if you read the entire description it plainly states a 1" impeller, along with 1/2 and 3/4 pipe sizes. First sentence states it is a 1" cam driven pump, referring to the width of the impeller not the diameter.
    Larry
    62 Bel-Air 409
    2016 Corvette Z51
    ptc
    ptc is offline
    Oct 2010
    Sacramento Area
    Got it Larry - I fixed my posts for the record.
