Hey Mouz! - Page 2
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 15 to 28 of 34
Hey Mouz!
  1. #15
    Kent, WA
    Do you have any with the hat CORRECTLY mounted ?????
    Peoria, AZ
    Yes, that will be on the drag boat edition. Until then you have to settle for the correct circle boat direction.
    Paul
  4. #17
    Upstanding Member Sharp Shooter's Avatar
    The Parking lot
    Quote Originally Posted by rich View Post
    Hi Jerry, Did you receive my Paypal just checking.Thanks Rich
    I'm not seeing anything Rich.
    The Parking lot
    Maybe I'll do the next set forward. It's easy enough to change.
  7. #19
    The Parking lot
    I received your payment Rich. I'm going to refund you $5 for shipping since it cost the same to ship 2. Thanks
    I need your address.
  8. #20
    Italian-Rage rich's Avatar
    Fort Mohave AZ.
    Quote Originally Posted by Sharp Shooter View Post
    Thanks Jerry, 4825 S Hwy 95 Suite 2 #256 Fort Mohave AZ. 86426
  9. #21
    Fort Mohave AZ.
    Default Address
  10. #22
    Senior Member Mouzer's Avatar
    corona ca
    got mine thanks jerry dig the plate frame and sticker..going right on my truck......
    ''''''OWNER OF THE BIG WHITE WOLF....,,,
  11. #23
    The Parking lot
    Sent yours out today.
    Installation instruction.
    Step 1
    Prepare the sticker for application by firmly rubbing a squeegee or credit card across the clear transfer tape. This removes any air bubbles that may have formed and makes the sticker cling to the transfer tape.
    Step 2
    Clean the area with rubbing alcohol or soap and water. Do not use Windex. Place the sticker in the desired location with a piece of masking tape on the top of the sticker to hold it in place. Cut into 3 parts between letters.
    Step 3
    Lift the sticker up and peel the white paper backing off the sticker. Be careful not to pull the masking tape off. Hold on to the bottom of the sticker.
    Step 4
    Slowly lower the sticker and rub it in place with a squeegee or credit card. Start at the top middle and then the outer edges. Firmly rub the sticker in place to make sure there is no air trapped under the sticker. Repeat for each part.
    Step 5
    For best results wait 24 hours then slowly peel the clear cover off at an angle. Be careful not to pull the sticker off the surface. If the sticker pulls away from the surface repeat step 4.
  12. #24
    Fort Mohave AZ.
    Step 1
    Step 2
    Step 3
    Step 4
    Step 5
    Thanks Jerry
  13. #25
    The Parking lot
    How's this?
Name:	K Vinyal Hat Forward.jpg
    Made a Drag boat too.
Name:	Drag Boat with Spray.jpg
  14. #26
    Late Start-er JusTrouble's Avatar
    Aug 2013
    Central Valley (Clovis) CA
    Jerry, those are all nice but how about a ski boat? I mean, since you are on a roll!
    JT
    I dont NO much.
    I would rather have it and not need it than need it and not have it.
    Favorite fortune cookie: Character is who you are when no one is watching.
  15. #27
    The Parking lot
    Quote Originally Posted by JusTrouble View Post
    JT
    Maybe, but this get's out of control quick. Hat forward vs hat back, wing no wing, injection or carbs, ot's or through transom. Everybody wants their exact boat and I can't do that. hahaha
  16. #28
    Peoria, AZ
    Jerry, I have a unicycle with stack injection, wheelie bars and promod raised wing. I wear a size 14 shoe and you know my height and build. Oh, and I have ape hangers on the front as well. Can you have that ready by 8:30 am tomorrow morning for me? Don’t forget my paint design I have had on my last five race helmets. Thanks Jerry.
    Paul
