1976 Kindsvater NOS Build
Results 1 to 7 of 7
    Member Craig_Mumma's Avatar
    Jul 2009
    Brea, CA
    Default 1976 Kindsvater NOS Build
    A few months I acquired this 19' 1976 Kindsvater from a friend, it was ordered in 1976 and never rigged. Currently the plan is a mild BBC with EFI (I know I could be dealing with hell on the EFI, but I have a plan if all else fails then I will resort to carbs), the rigging is being done by Don Mumma at Fantasy Rigging. The plan is to rig it modern with a vintage touch, Here are some progress pics from when I got the boat to where it is today. The plan is to have it complete for Flat Bottom Boogie, if I miss that date it will be at Wades Paradise New Years Day. The trailer needs a bunch of work, so i made a dolly for the boat, so Don had an easy platform to work from. You can see in the pics how tight the v-drive math turned out, adding the whirl-away really made it a tight fit with the coupler and seal, the safety collar will need to be placed underneath, motor will sit low and at 3 degrees. The seats will be bench front and rear and the exhaust will be over transom, I was hoping for through transom but it will be too tight after motor placement. I still need to make decisions on interior color/pattern/material, polishing and anodize color.
ID:	1035987   Click image for larger version.
ID:	1035989   Click image for larger version.
ID:	1035991   Click image for larger version.
ID:	1035993   Click image for larger version.
ID:	1035997   Click image for larger version.
ID:	1035999   Click image for larger version.
ID:	1036001   Click image for larger version.
ID:	1036003   Click image for larger version.
ID:	1036007   Click image for larger version.
ID:	1036009   Click image for larger version.
ID:	1036011   Click image for larger version.
ID:	1036013   Click image for larger version.
    Senior Member Mouzer's Avatar
    corona ca
    looking awsome......................
    ''''''OWNER OF THE BIG WHITE WOLF....,,,
    Senior Member SPECTRA-SANGER's Avatar
    Sep 2016
    Such a great project! your hard line work looks awesome, any close ups of that?
    Jul 2009
    Brea, CA
    Quote Originally Posted by SPECTRA-SANGER View Post
    I would love to take credit for the engine and hard lines, but that was done by "Xfuelracer" here on the forums. Gary is the one that started to set this motor up for EFI, hence the thermostat and also the way he was dumping the water through a bassett pressure regulator into the exhaust so that water reversion did not happen at idle killing the O2 sensor.
ID:	1036017   Click image for larger version.
ID:	1036019   Click image for larger version.
    Sep 2016
    thank you for posting, I have wanted to get into building some hardline and this gives me some motivation! Just love the hardware you are using as well, I cant recall the last time I saw a Stellings front cover... super cool!!!!
    Jul 2009
    Brea, CA
    Progress....
ID:	1036097   Click image for larger version.
ID:	1036099   Click image for larger version.
    Sep 2016
    That just looks Bitchen, the silver metal flake blends so well with the polished aluminum, perfect!
