Bimini top question
Results 1 to 10 of 10
Bimini top question
    Aquacraft Eddie's Avatar
    El Paso TX.
    Default Bimini top question
    Just wondering how many of you have Bimini tops or had them on your flat? Iv been thinking about getting one since we just use the boat as a ski boat but I’ve been hesitant because I’m not sure how well they are on a flat bottom and I don’t like the idea of drilling holes in the boat so any suggestions or experience with them is appreciated, also who and where is the best place to get one ? Thanks
    El Paso TX.
    anyone have a bimini top on their flatty? pros/ cons? is it worth it ? also just wondering about casale gears,,im running around 400-450 horse at most and iv got 18% gears and im just wondering what gears are most people running just for a ski boat? thanks
    FWIW I run A bimini on all my cruisers For the shade for my wife kids and grand kids. As far as gears go, the 18* gear is the normal "go to gear" for most cruisers or flats for all around performance. I.E. pulling skiers and cruising. My 20' Eliminator sport cruiser has 18's in it now but am thinking of stepping up to a 22-25 gear but I have a transmission so I can stretch it out a-bit. For a flat I would leave the gears alone if putting and pulling skiers is your'e main focus for the boat.
    Steady Rollin
    Corona
    as far as the bimini goes, i'd REALLY try to get creative and do some hidden mounts under the deck. It would be a shame to have a bunch of hardware visible on a flat
    El Paso TX.
    Thank you both for the info!,,so im leaving the gears alone just pulling skiiers and who do you guys recommend for bimini tops at a good price? i hate to have the hardware showing and drilling holes in her also that was my concern so i thought maybe someone here might have had a trick set up but if not its ok thanks again!
    Steady Rollin
    Corona
    Quote Originally Posted by Eddie View Post
    I'd find someone local to make it, thats really the only way to get it so it looks RIGHT. It looks like you're in TX, so you might have to do some research to see who does good work out there. A proper shop should be able to custom make it to fit your needs, but it wont be cheap, but it'll look right.
    You'll want stainless poles and hardware.
    Old Timer LeE ss13's Avatar
    San Dimas CA
    Bimini tops are not legal on 18 ft flatbottoms in SoCal. The Bimini top police will wright you a ticket. If not I will wright you a ticket.
    El Paso TX.
    Quote Originally Posted by LeE ss13 View Post
    Thanks for the heads up,,I know it looks ugly but im only skiing and tubing the sun is crazy here its always around 100 plus degrees at the lake im slowly cooking my daughter and wife and myself im still on the fence about it and theres nobody here to fabricate one that I know of or trust Im looking into other options,,,
    Senior Member Mouzer's Avatar
    corona ca
    its been done.....................keep the wife and kids out of the sun.
    Mar 2017
    I just met a guy at the lake with a blown hondo t deck that had a Bimini mounted on a rail system drilled into the top of the hull. It was ugly as all be. But it was functional while just cruising. Not my cup of tea.
