Knowledge base and the information lost on HB
Results 1 to 14 of 14
    PB Administrator Performance Boats's Avatar
    Nov 2007
    Blog Entries
    1
    Default Knowledge base and the information lost on HB
    A little while back I saw a thread in here about a lot of good knowledge that was lost when HB's forums went out. People mentioned wiring diagrams and stuff like that. The new wiki (see button at top) is the perfect place for all this stuff. I am committed to making it the ultimate boating knowledge base, and you can help. If you are not familiar with a wiki or are having trouble posting to it you can shoot me a PM and I will personally call you to help.
    I don't know crap about the wiki button; however on this site, if anybody needs to know ANYTHING!!! there are people here that know EVERYTHING!!!
    The list is long and distingushed; like Joe Shelfo (Jr. and Sr.), Billy B, Wilkes,Fiat 48, Guru
    Super Dave, and need I mention RCL, or Sammons, Hud, Dossangers, and it goes on and on and on... It has been my expierence that whatever you need to know about a (real boat) there are very knowledgeable folks here that don't mind helping out. That's why we v-drive. STEVE
    Senior Member ColeTR2's Avatar
    Parker, AZ
    Quote Originally Posted by admin View Post
    I don't see it
    ..... rivergames's Avatar
    Los Angeles / Parker
    its next to the forums button at the top of the page
    Senior Member Roaddogg 4040's Avatar
    Lake Havasu City, AZ/Algonac, MI
    Mike... You have to hit the contact button and then you will see the wiki button on the next page... At least that is how I found it...
    Steve
    I'm famous ! Lucky's Avatar
    Ukiah,Ca
    ammm Please re read your title - Traci may go ape shit
    [/SIGPIC]
    The Earth
    Blog Entries
    24
    It's a shame we can't retrieve some of those tech threads that were on hotboat.
    Colts fan & Stoker owner RitcheyRch's Avatar
    Santa Clarita Valley
    So very true. Was some valuable info there.
    www.facebook.com/RitcheyRch
    "I didn't pay them for sex, I paid them to leave"
    Charlie Sheen
    Life is all about ass, you're either covering it, hauling it, laughing it off, kicking it, kissing it, busting it, trying to get a piece of it, or behaving like one.
    Gone
    Sparks, Nevada
    It took years. It's probably gone.
    Already miss the 310/562 2manymustangs's Avatar
    WET MEMBER SANGER-RICH's Avatar
    AMERICAN CANYON
    They also burned all the past issues of Hot Boat
    2008 & 2012 NJBA HIGH POINTS CHAMPION
    2012 SKI HYDRO ET RECORD HOLDER AT 9.51
    2012 SKY HYDRO SPEED RECORD HOLDER AT 116.27
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Well fortunately I post on more than 1 board. 3 actually and 2 of them still around.
    But this is exactly how it started.
    Here is one that I whipped up a while back. The three most common GM firing orders. I needed a visual means of comparing the differences. A big difference when viewed as a continuation of the engine running.
    http://marineassault.net/2113-med.jpg
    This is a CID chart I made for myself as a quick reference. Put it on the back of my business card also.
    http://marineassault.net/211CID_Chart.jpg
    A quick reference on where the piston ring gaps should end up.
    http://marineassault.net/Gaps.jpg
    The list goes on .................................................. ..................
    Engine calculators
    Mortec
    Blower Drive Ratio Chart
    Smokemup.com
    Head Milling vs Compression Chart
    Camshaft Degreeing - Intake Centerline Method
    Camshaft Degreeing - .050 Method
    Fuel Injection Notes
    Ford 460 Tech
    VIN # Decoding
    NGK Plug Heat Range Chart
    Autolite Spark Plug Heat Range Chart (pdf)
    Champion Spark Plug Heat Range Chart (pdf)
    Tips on reading Spark Plugs
    ARP Fastener Torque Specifications (pdf) There's more useful bolt info on the ARP Website
    Basics of driveline angle and U-Joint function
    Find a boat MIC (manufacturer identification code) here
    Blower Belt Length Chart
    Barry Grant Jet & Nozzle Sizes
    Bearing Clearance Info - Federal Mogul
    Simple Rocker Arm Geometry Check
    Setting Valve Spring & Valve Stem Heights
    Common Racing Fuel Specs
    VP Race Fuel Specs
    Racing Gas Basics - Klotz
    Racing Gas Octane
    Race Gas vs. Av Gas - 76 (pdf file)
    Fuel info on How Stuff Works
    76 Race Gas Specs
    Aftermarket Chevy Starter Gear Clearance
    Chevy Cyl Head Flow Comparison by brand (pdf)
    Deck heights, rod lengths, compression heights various engines:
    Oil Filter Comparison
    Standard Boat Wiring Color Codes.
    Blk -Grounds-General
    Blk/Brn -Pump Grounds
    Blk/Red -Voltmeter Grounds
    Blk/Org -Isolated Accessory Grounds
    Blk/Yel -ignition stop
    Blk/Grn -Water Level Sender Ground
    Blk/Blu -Lighting Grounds
    Blk/Gry -Nav Light Grounds
    Blk/Wht -Battery Parallel Solenoid
    Brown -Pumps-General, Bilge or Sump (Manually Switched)(Also alternator starter to Ign.)
    Brn/Red -Pumps, Bilge or Sump
    Brn/Org -Power feed to Auto Bilge Switches-Pumps, Fuel/Oil Tranfer or Priming
    Brn/Yel -Baitwell or Aerator
    Brn/Grn -Fresh Water Pump/Water Maker
    Brn/Blu -Head Pump
    Brn/Vio -Washdown Pump
    Brn/Wht -trim pos sender
    Red - Battery Feeds Unprotected
    Red/Vio -Misc. Accy. Main Feed Protected (fused) from batt to trim panel.
    Pink -Fuel Sender
    Org/Blk -Audio System Feed
    Org/Brn -Electric Head-Sanitation System
    Org/Red -Wiper Port
    Orange -Accessories common feed- Dist Panel to Acc switch-Anode Electrode-Mercathode
    Org/Yel -Diesel Pre-heat
    Org/Grn -Wiper Stbd
    Org/Blu -Communications Equipment
    Org/Vio -Navigation Equipment
    Org/Wht -Wiper Center
    Yel/Blk -Choke - Neutral saftey trans mounted
    Yel/Red -Start Solenoid(starting circut), Neutral Safety
    Yel/Org -Powered Ventilation, Fans
    Yellow -Bilge Blowers -(also alternator DC output)
    Yel/Wht -Rudder Angle Sender
    Grn/Red -Stop Solenoid/Kill Switch
    Grn/Yel -AC Grounding
    Green -Bonding
    Grn/Wht -Engine Trim in and or tilt down
    Grn/Org -Engine Independent Trim down
    Blu/Blk -Cabin Lights
    Blu/Brn -Oil Temp Send
    Blu/Red -Cabin or Cockpit Lights Port
    Blu/Org -Engine Independent Tilt Up
    Blu/Yel -Lighting Circuits to Remote Send
    Blu/Grn -Cabin or Cockpit Lights Stbd
    Blu -Instrument & General Lighting
    Blu/Vio -Courtesy, Boarding Lighting
    Blu/Wht -Engine Trim Outand/or Tilt Up
    Light Blue -Oil Pressure
    Vio/Red -Eng. or Generator B+ from Breaker
    Vio/Yel -I/O Trim Up (ballast bypass)
    Vio/Grn -I/O Trim Down
    Vio -12v Ignition-Generator or Engine
    Vio/Wht -Trim "Trailer" switch
    Gry/Blk -Mast Light
    Gry/Red -Spotlight Remote
    Gry/Org -Docking Lights
    Gry/Grn -Strobe or Beacon
    Gry/Blu -Spreader/Flood Lights
    Gry/Vio -Windlass/Winch
    Gray -Navigation (running) Lights, Tach. Send
    Gry/Wht -Anchor Light
    Wht/Brn -Temp. Alarm or Indicator
    Wht/Red -Fuel Alarm or Indicator -((Ignition module to Dist.)Mercury Thunderbolt Ignition)
    Wht/Org -Fire Alarm or Indicator
    Wht/Yel -Air Flow Alarm or Indicator
    Wht/Grn -Water Press/Flow Alarm or Indicator - ((Ignition module to Dist.)Mercury Thunderbolt Ignition)
    Wht/Blu -Oil Press Alarm or Indicator
    Wht/Vio -Voltage Alarm or Indicator
    White -General Alarm Usage, Yamaha Kill Switch
    Tan - Water Temp sender
    Tan/Blu -Warning system sense wire (Audio warning)
    Pink -Fuel sender
    Calculating Valve Timing Events:
    Intake Opening
    Duration/2 = Sum - Intake Centerline = Intake Opening
    Intake Closing
    (Intake Opening + Centerline) / 2 = Intake Closing
    To figure exhaust, Opposite of Intake.
    Overlap is IO + EC.
    http://www.reincarnation-automotive....s_2_dovec.html
    Dude, thanks for posting this link, I lost it several years ago and couldnt remember the company's name. The Duraspark info and the 385 series info is pretty good!
    Nov 2007
    Blog Entries
    1
    Nice, I will start integrating these. I hope to have a tutorial for posting in the wiki here shortly.
    Regarding seeing the wiki button, you might have to clear your cache to see it.
