Winter Project Time. Who is doing what?
Results 1 to 14 of 80
    Senior Member BigBoyToys's Avatar
    Spokane, WA
    Default Winter Project Time. Who is doing what?
    Need to get through these cold snowy winter months so I just picked up a T-Deck Jet and will be rebuilding it from the ground up. I also need to finish up the Daycruiser but that is Just Interior and I will be paying an upholsterer to do that so it ain't much of a Winter Project. WHo else has a Winter Project?
    Silverdale, Washington
    Just setup stuff on mine Jim. Nothing too exciting. May swap some pulleys around if Barry will let me...
    Colfax, Ca
    Replacing head gaskets on an engine someone sold me
    Powder coating motor plates, etc.
    Camino,Ca.
    what color?
    Salem,Or
    throwing in a cam kit, heads , putting the tunnel ram back on, headders.
    thats about it
    Spokane, WA
    I think you ought to sell it back to him at the same price you paid
    spokane, WA
    Building a new engine for my 19.........
    Travis
    Senior Member T-Train's Avatar
    Jul 2009
    Lebanon,Or
    Replacing cables adding a water seperator replacing the u-joints on the driveline. Maybe some powder coating. Little stuff.
    oregondunes oregondunes's Avatar
    Sep 2009
    Tualatin, Oregon
    Carpet and Upholstery. Revamp the trailer........easy stuff
    Spokane, WA
    Quote Originally Posted by TwinTurbo540 View Post
    Travis
    I thought you were gonna get a 21'?
    Spokane, WA
    Oh, this should get interesting for me trying to figure this out. I just picked up a Berkeley 12JC which is going to get the conversion to a split bowl as well as a COMPLETE racing type prep done. Inducer, SS Impeller, etc etc. ANd I will also be building a motor. Would like to keep the motor in the 496ci BBC range but am looking to get 800 HP out of it at the Optimal RPM's to match the pump. Since I haven't built either the pump or motor yet, I guess I have alot of research to do as to what parts will work best to get me a 496c BBC Normally Aspirated that will put out 800+ hp @ XXXX RPM's (Depends on Impeller and Pump setup???) I know I can get the horsepower, it may take some CNC Alum Heads, big Compression, lotsa lift, and some big carbs, but it can be done. But getting the Horsepower in the right RPM range to match the pump might be a challenge.
    I was even looking at saving up for a DRCE Motor...... But I'm pretty sure that would be not so easy matching up to a pump because they typically are High RPM apps (Great for props, not so great for pumps?)
    Any ideas, recommendations, suggestions?
    spokane, WA
    Quote Originally Posted by BigBoyToys View Post
    Was thinking about it it but 1400hp+ will be much more fun in the 19 for now....
    Travis
    Do Steve and Shirley still have that one? That was so badass....
    spokane, WA
