is this motor heading in the right direction
Results 1 to 2 of 2
    Dec 2012
    wittmann
    Default is this motor heading in the right direction
    i got a 460 stock rotating assembly was told heads had alot of work done to them what idk bought that way has lunati 280 cam w lifters roller rockers weiland stealth intake hei distributer gear driven timing basset shortys and 750 holley dbl pumper jet is berkeley split bowl a cut aluminum impeller droop snoot ride plate place diverter and speed loader tell me what to do what not to do tips and advice thanks
    Senior Member SBS933's Avatar
    Jun 2012
    You should post this in On The Dyno, all the experts are there.
