how to anchor in the river
Results 1 to 14 of 34
    Member boataholic's Avatar
    Apr 2009
    Murrieta, CA
    Default how to anchor in the river
    What is the best way to anchor a boat at the river. Every year I go I fight all weekend long. Any suggestions?
    River Rat
    Martinez Lake, Arizona
    How big is your boat and where are you trying to anchor?
    On the lower Colorado, I use a danforth style anchor when I'm at a sandbar. I anchor it off the sandbar in the current. If there is alot of boat traffic, I'll throw a sand anchor off the back to keep it from creeping up on the sandbar.
    When we're fishing, or just hanging in clear lake, I'll just anchor with the sand anchor and all is well.
    My boat ain't that heavy though..... 20.5 Advantage Bowrider with a 225 Merc.....
    Seriously, just go buy a box anchor, throw it in, and your done. It's that simple. A box anchor will hold three boats on the river.
    Darrell.
    San Diego.
    28ft Sportcat
    With Twins
    RvRrat
    Guest
    Use the biggest hooker (anchor) you can get. I think mine is 17lbs. I have about 10-12' of heavy chain then another 50'+ anchorline river style. When all the other anchors pull out (box's included) mine hangs in there. Never pulled up so far.
    two strokes is enough
    Yuma, Az
    when your looking for an anchor the size you think will do wont put it back and get a bigger one then dpending on your boat if its a tunnel good luck keeping it straight no matter how you anchor it it will aways have its nose in the wind depeding on size of course. just buy an anchor that is plenty heavy.
    and if you can reach the bottom then bury it and you will be fine
    Apr 2009
    Murrieta, CA
    I have tried the box anchor, but that did not seem to be enough. the boat would still move down river. My boat is a 24' cheetah. I mostly have this pproblem when we are in parker. It just seems as if my box anchor needs to have more weight to help.
    San Diego, CA
    some places in parker have lots of rocks, I would get a box anchor for that stuff, for sandy area I use danforth everytime, hook it to the boat and throw it overboard and forget about it
    Boat 405.
    New here Beer:30's Avatar
    Bakersfield, CA
    Quote Originally Posted by boataholic View Post
    The biggest mistake (done it) with box anchors is not enough rope. If rope is too short it is pulling UP on the anchor. Just when you think you have enough rope on it, add 25 feet.
    Punk in Drublic Tiggle - Bitties's Avatar
    SoCal
    The northern part of Parker (Castlerock, Riverlodge II, etc...) have some "special" permanent anchoring blocks (couple of cement filled trashcans, motor block and a few boulders) that hold our boat... Otherwise a good lenght of rope on a box anchor seems to work for us!
    Originally Posted by bocco
    "One more thing. Boobs are like boat motors. I never heard a woman say she wished she had gone smaller"
    Got to get In da Wind NdaWind's Avatar
    Lake Elsinore, CA
    first time at Buckskin our box anchor couldn't get enough rope and chain out because of other watercraft using same area. We got a anchor bungy and that thing hooked to the box anchor held better than having a 100' of rope. Also tied the rear of the boat to large rock in case the anchor failed. use that bungy now when ever we go out and there's going to be some wake action. bungy gives a little without pulling up anchor.
    Senior Member fed4life's Avatar
    I do the same NDAwind does. I have 21' Aftershock and i use a box anchor with a big heavy duty bungee line i bought from West Marine and it has no problem setting in Parker, even in the strongest of currents. Last Summer a nasty monsoon storm came quick in the morning with winds gusting to probably about 50 m.p.h. or so and the box anchor held no problem.
    If you use a hard line it will eventually pull up the box anchor or any anchor for that matter unless you use a gigantic danforth anchor with a heavy ass chain which is cumbersome, takes up to much space and just flat out sucks to work with.
    When im at the lower sandbar at Parker i use my box anchor off the bow and my slide anchor of the stern(facing toward shallower water). With the slide anchor in the back i use a small hard line since there isnt any chop there to pull it up. With that set-up i have my boat and 2 of my buddies boats( two other 21') tied up to me on either side and we dont move at all.
    Maybe you already do but tie a bright colored bouy or something similiar to your bungee line and mark it with something to let you and other people know its your line and where your anchor is. And if your at the sandbar try to tie something off at your anchor like a water bottle or fender to let people know where your anchor exactly is so they dont step on it and slice their foot open. This is especially important with box anchors but is a good idea to do it with slide anchors that are underwater and cant be seen so people dont jam there toes walking into it.
    Apr 2009
    Go buy a box anchor it will be the best 130.00 bucks you ever spend. I was always fighting with my old anchor plus you don't need any chain. Well worth it!
    Apr 2009
    Murrieta, CA
    Do you guys think the small box anchor would work for a 24 foot or should I step up and get the large.
    Yuma, Az
    small one should work but if your worried about it go big
