Thru Hull Exhaust.........
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 44
    Default Thru Hull Exhaust.........
    Hey guys on my carrera 20.5 elite, exhaust goes out thru the prop.....whats involved with changing that to exit out the back under my swim steps, or is it too much work. Im not to concerned with trying to gain power, more of a sound thing..........
    460 is offline
    ATTA BOY 460's Avatar
    Go down to the props and drive section. I bet sumone there might be able to answer that
    Good idea.........
    Banne'd Cobra1's Avatar
    Take off the yoke, and put on the block off plate, easy. Then go to the back and tape off the area that the tips will be. With masking tape you will be able to mark it better than on the gel, if you don't like it start over. Leave the tape on when you drill the hole out with a hole saw. Treat the newly exposed wood, install new through hull tips. Go to Bergeron, grab a new jar of vasoline, and bend over. He should have the exhaust hose in the parts room on the south end of the office. He might have the block off plate as well and I.m sure he can "hook you up" with the new tips as well.
    If ya need help call Cave, it looks like he knows his way around a bilge, since he's been in his all spring. Oh I slay me.
    here's the part.
    http://www.danamarineproducts.com/Me...ckOffPlate.htm
    http://www.perfprotech.com/store/ass...,2705-290.aspx
    You might give REX a gingle I'm sure he has them as well.
    Oh yea, keep the yoke for the jet boat guy's. They use them to play horse shoes, they need all of the advantage they can get.
    ive allways had headers on jets, so i dont need to adjust the water or anything on the stock set-up just run it out the back....
    Quote Originally Posted by AzEliminator View Post
    No, all you are doing is re-routing the exaust. The water will still come out the riser and then straight out through the tip. Nothing to adjust.
    Thats what im looking for, should sound a little better........
    Im not really doing it for performance, but i wonder if doing it that way makes any diffrence.....
    Yes. But the issue that some people have with them is the higth. They have them out of the water at idle, kinda loud. It's up to you, but if you ever have to do a dbl test at idle, they might pop you. For me I would keep them below the water at idle speed.
    thanks for the info cobra, i think thell be ok, hell even out of the water there still going to be quiter than all my buddies jet boats, just want something that sounds a little healthy........
    good luck. It's no a hard job. It's just getting to freaking HOT out.
    Dad has a big ass cooler in his garage, were good.........
    460
    460 is offline
    Quote Originally Posted by Cobra1 View Post
    You sure are talking an aful lot of shit as of late. One day all this shit is going to catch up with you.
