Should We?
Results 1 to 8 of 8
Should We?
    Default Should We?
    We are thinking of adding an air compressor to the boat to blow up tubes and rafts. Should it be mounted under the hatch? What size and brand of compressor should I be looking at? How much should I expect to spend?
    Impeachment! 75 TX's Avatar
    Culver City, Ca
    I'd look into compressors used in automotive airbag suspension applications. A compressor and perhaps even a small tank would certainly make things easier. If your charging system can handle it....
    Here's a few, starting @ $130.
    http://www.airbagit.com/Air_Bag_Compressors_s/29.htm
    Senior Member 78Eliminator's Avatar
    i use one of those portable ones you plug in your lighter and works great for me.
    why go with a built in compressor? Seems a bit much for blowing up toys. I have a 12v 1 gallon (?) wet/dry vac that does the same. Comes in real handy when the mid cabin gets soaked or sand is all over the place. Flip the fitting around and you have your blower. Just another idea...
    Culver City, Ca
    Quote Originally Posted by SlowSquirt View Post
    That's a fine idea. Hadn't thought of that
    Sep 2008
    Yuma, Az
    buy one of these at wal-mart for $25 bucks, use alligator clips instead of the cig lighter plug and connect it to your battery; or just add a cig lighter to your boat.
    boatless....
    Talking Thanks
    Thanks the for the information.
    Full Of It. Mandelon's Avatar
    Sandy Eggo
    Quote Originally Posted by YumaJet View Post
    That's like what we use. It takes a few minutes to blow up a big tube, but works just fine for not much $$$$
