need a machine shop in northern utah
Results 1 to 5 of 5
    Jul 2010
    10 Minutes from Pineview reservoir, Utah
    Default need a machine shop in northern utah
    Thinking about buying this hallet with a cracked block. (454) anybody gotta line on a machine shop or a good big block ? Will a 496 have the same bolt pattern, im kicking around the idea of dropping one of those in... thanks
    1976 carina mercruiser 165hp 18 ft... just a cruiser...
    Senior Member flat chance's Avatar
    Copperton, Utah
    A 496 is pretty much interchangeable with a 454. I was just asking my brother if he wanted to let his Ls6 454 go. It's already set up for a marine application, mounts and all. If not, you should'nt have a problem finding one in a junk yard. Dime a dozen.
    Jul 2010
    so to make it a "marine" block it needs, brass freeze plugs and different gaskets ?
    Senior Member Sleek Freak's Avatar
    Hooper Utah
    Felts in Ogden will do you a good job.
    Jul 2010
    Right on man thanks.....edit....... nice i only live a few blocks from their, ill stop and talk to them before work tomorrow
