mounting nitrous bottle - Page 2
Page 2 of 2 FirstFirst 1 2
Results 15 to 18 of 18
  1. #15
    CANT RE MEMBER FARMER JOHN's Avatar
    Sep 2008
    DOME VALLEY,AZ
    something that you need to think about, When was the last time your boat sat level in the water? and on the launch the bow rises and then exceleration moves the liquid to the back, I run mine at a slight angle and under the seats so as to keep it out of the sun, and the mount is an old fuel tank that i cut up and put a 1/4" foam insulation inside it then i just slide the bottle in it and clamp it down.
    Senior Member lupo1904's Avatar
    Feb 2011
    Good deal farmer john, i have heard alot about you from the bostick and seen alot of your machines on the forums but still have not meet you. Thanks for the input. What is the purpose of a bottle warmer? Doesnt juice like to be about 70 degrees? I have seen guys keep there bottles in the water at the river which isnt a bad idea
  4. #17
    Sep 2008
    DOME VALLEY,AZ
    thats why it works good the old fuel tank with the insulation inside of it and then the bottle inside of that helps keep the bottle temp down in the summer and the clamp is on the end of the section of the fuel tank (only about 18" long) its real easy to change bottles.
    If your down at fishers this summer i will look forward to meeting you
    Feb 2011
    Thats the only place i go, ill be there mamorial weekend, keep an eye out for the brown trout
