nos question
Results 1 to 7 of 7
nos question
    Senior Member lupo1904's Avatar
    Feb 2011
    Default nos question
    I found plates and solinoids for sale but there are 150hp jets in them and the solinoids only go up to 200hp, im looking to run 300 to 400 shot . Question is if i buy these and get big shot solinoids and change the jets to 300 or 400 hp will the plates work?
    Southwest corner AR
    Quote Originally Posted by lupo1904 View Post
    You might have better luck in the Dyno Section! The plates I think maybe to small for the shot you want!
    WT
    WFL Crew!!!
    Feb 2011
    Ya im hearing to different things, one is that the spray bar for a big shot has more holes in it, then the seller says all i have ro do is change the jets and solinoids
    Southwest corner AR
    Im thinking either more holes or larger holes! And NOS is not something you play around with because the wrong setup will or can be a very very bad ending! You will no likey!!!
    Also who or how are you going to get a base setup from anyone that will even be close to right!
    WT
    WFL Crew!!!
    Feb 2011
    I already have a system on my boat but i borrowed it and would like to give it back, the guy i borrowed it knows his nos stuff but i couldnt get ahold of him
    Senior Member Chuck Wagon's Avatar
    Palm Desert
    For Nos questions try yellow bullet.com good info there
    Feb 2011
