MSD 83606 Distributor
Results 1 to 2 of 2
    Jan 2012
    Independence KS
    Default MSD 83606 Distributor
    Is any one running this unit? It says it has a rev limiter built in or am i reading the part description wrong. Hefty price tag but would do away with the box right?
    Southwest corner AR
    For what you are running an HEI would work great! Unless you have a tunnel ram and room is an issue! There is a later model HEI that uses a external coil and is locked out with a small cap design too! Way less expensive!
    WT
    WFL Crew!!!
