cam selection
Results 1 to 14 of 24
cam selection
    Senior Member motor head's Avatar
    Jan 2011
    Default cam selection
    So what kinda duration @.050 and lobe sep are you guys running? I'm only going to be at 10:1 with my 557 with heads that only flow around 320cfm @ a little over .600 lift so I don't want to go real big.
    [SIGPIC]
    Jan 2011
    This is the little cam I run now in my 472 with 9.5:1 compression
    http://m.summitracing.com/parts/cca-34-336-4
    [SIGPIC]
    Jan 2011
    If I change cam and springs it will be mechanical roller so I was thinking of this one.
    http://m.summitracing.com/parts/hrs-241593-12
    [SIGPIC]
    Senior Member 18GullwingMailman's Avatar
    Dec 2010
    Conway, AR
    Default Cam selection
    Quote Originally Posted by motor head View Post
    Ahhhh - hell with all that! Second one from the bottom!!!
    Better yet - ask Travis where to get a cam!!!
    WFL Crew <----------> WFL Crew
    Try this. Depending on carb and exhaust should get you 650-700 hp. lope sep=112 lift Int- 680. EXH LIFT 646. dur at .020 Int 288 exh 298
    Senior Member hotbo's Avatar
    lake Ouachita AR
    Bobby you know your heads are going to be way small.
    call Bullet!
    WFLC
    2011 Performer SS
    built by Scott Seastrom.
    Jan 2011
    Yeah that's one of the reasons I didn't build the 557 yet Travis. I was going to wait until I got a nice set of heads but screw it now. It should still make the boat quicker due to the torque.
    [SIGPIC]
    Southwest corner AR
    Bobby, what heads were you thinking for this big motor! Ford or aftermarket? There is a guy on the boards here that knows his Fords and he could steer you in the right direction!
    Is this cam you have Hyd or solid lift?
    WT
    WFL Crew!!!
    Jan 2011
    The little cam I'm running now is hydraulic flat tappet. The 557 came with a mechanical roller that is .712 lift, 274 duration @ .050 and 110 lobe sep. I just think that is way too big for a 10:1 motor and heads that may not let it make hp over 6,000rpm?
    [SIGPIC]
    Jan 2011
    I'll eventually save the money to get some p51's or better but any super good head I buy I'll have to change pistons or fly cut mine.
    [SIGPIC]
    Call John Partridge at Bullet. He will sell you a cam but he will also tell you to run the one you got.
    Jan 2011
    that's three people that told me to call now. Travis, Chop, and you so I guess I will tomorrow. Thanks guys!
    [SIGPIC]
    lake Ouachita AR
    its not that hard!pic up the phone and dial Goober head!
    WFLC
    2011 Performer SS
    Jan 2011
    [SIGPIC]
