57 MPH @ 5100 RPM ( what gives) ???????
Results 1 to 3 of 3
    Jan 2012
    Independence KS
    Default 57 MPH @ 5100 RPM ( what gives) ???????
    Low Down
    1986 TX-19 with Fresh 461 BBC. Motor man says motor is 9.5:1 pushing around 450 ponys. Have a standard 1310 H-bar/driveline from Tom at JBP.
    Pump is a Dom 12-S split bowl. Impellar is unkown. NO loader, shoe, or Droop not even a rock grate( I Know). Has a ride Plate and new Place diverter. Pump is set back I think. Inspection cover splits the the transom about 50%. Pretty sure it needs rebuilt but noting was loose when i bought it and makes no noise when im driving. Ive been told by Tom this config should be running 70 with 4 grown adults. I belive its a light lay up boat. 3/4'' stringers when i bought it. One man can easly lift off trailor when empty pump out of course. What do i need to do to get this boat running like it should. From some of the video of my boat it seams to ride wet.
    Atlanta, Texas, United States
    Quote Originally Posted by KansasJet View Post
    Low Down
    KJ,
    Without getting into a long detailed conversation, as seeing with eyes may be much better than words, you might consider pulling the boat down to Hot Springs to Tigertooth's shop. Since you are heading there anyway, he could probably keep it in his fence and could look at the boat real quick and tell you what is going on.
    Gear
    Mar 2010
    Clarksville, TN
    Ya gotta get a loader. Most of us run 1 from MPD. That will help. Your in about the same boat Nerve Damage is in. Read that Ride plate angle thread and do about the same. With ur HP 70 mph shouldn't be hard to get.
    And ur pump is in a stock location for a GW
