Trying to get high maintenance setup
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 55
    Senior Member motor head's Avatar
    Jan 2011
    Default Trying to get high maintenance setup
    I bought an angle finder today so I can see where I'm at on the setup. Ride plate is 1.5 degrees up from the keel and the nozzle is 5. From what iv read 3 &4 are a good starting point and 4 &7 is the magic numbers on most wingers so Iv been way off.
    [SIGPIC]
    Southwest corner AR
    It also depends on the type of droop you are running. Stright,short,full they all are setup differently with the wedge. I have been told you want no more than 10* up and set the plate at or around 3* up to start! I have heard of 5* but, I haven't heard of 7*! Grady has been playing with his and he may can tell you more.
    WT
    WFL Crew!!!
    Jan 2011
    I meant 4 on the plate and 7 on the nozzle when I said 4&7.
    [SIGPIC]
    Mar 2010
    Clarksville, TN
    4* on the plate is a good starting point
    Senior Member vmaxed's Avatar
    Sep 2010
    EAST LA (Lower Arkansas)
    Default back to 4
    I'm with TN 4 degrees to start. I run a half droop so I run my deverter a couple notches higher than the guys with full droops. Mine flies high at 4 didn't gps it but flies to high at 5. 4 degrees on plate, full droop 2 or 3 degrees of wedge 2 degree tapered shoe open loader and a 3.125 bushing is a good starting point
    Jan 2011
    Right now it has a 4deg wedge, full droop, and fixed race nozzle with a 3.125 insert. But the ride plate is only 1.5deg up from keel. Can't believe iv never checked it lol.
    I have a diverter now but I need to get it machined for an insert. Think I'm going to go with a 3.000 to start with.
    [SIGPIC]
    Sep 2010
    Default could be better
    My nose is to high and roost is to high also. I need to push the nose down direct the jet more into the water and lift the boat straight up. My motor is all the way back, I keep the tanks full and they are all the way back too. All working against my 240# but up front
    Sep 2010
    Default shoe and loader
    How far down are your shoe and loader
    Jan 2011
    I finally measured my impeller. It's a AA that has been cut some. It's now
    9 3/32 x 7 3/16. I thought it was an AB guess I'm making more hp than I thought!
    [SIGPIC]
    Mar 2010
    Clarksville, TN
    Quote Originally Posted by motor head View Post
    What would that be a A+ or A ?? What RPM you turnin
    Jan 2011
    Its same size as AA on big side and a little smaller than an A on the small side??
    It was turning 5800 last time out with a few issues. It should turn 6k next time it hits the water. I made a few small changes.
    [SIGPIC]
    Mar 2010
    Clarksville, TN
    Sounds like you have a A+. Just a odd size. What kinda MPH you running
    Jan 2011
    Chop said it's an A+ cut on a B angle. I haven't gps it with the new motor. Should be 90+
    [SIGPIC]
    Mar 2010
    Clarksville, TN
    What was you runnin at the 5800
