need advice on a 19 cp
Results 1 to 5 of 5
    Oct 2012
    Default need advice on a 19 cp
    I have a 400lb cp with a mersch intake, berkeley jet with stainless a, 500ci bbc (800 hp) and two fiberglass buckets. I was wondering what angle to set the nozzle and ride plate also how muxh shoe should i put in it. Thanks
    Senior Member vmaxed's Avatar
    Sep 2010
    EAST LA (Lower Arkansas)
    Default who knows
    Who knows what the best set up is? I'm NO expert but to start with on a tapered shoe start with 2° and 4° on the ride plate with an open loader and 3.125 nozzle. My loader is 3/16 below kell. From here you can tune more out of it. There are several threads on gull wing set ups on here. The pro style loader works good and MPD makes a loader some guys really like and some prefer a back cut shoe. These boats usually will go about 105 then they start to run out of water. After that they need keel work usually.
    Mar 2010
    Clarksville, TN
    Could be a totally different setup on a low pro intake. Give Chris (cs19) at B1 Racing a call. He can get you pointed in the right direction
    Just make 1 change at a time and alot of testing and tuning
    Sep 2010
    Default missed that fact
    I missed that important fact. Coonass's boat had one in it. It is a Warhawk built boat Tiger took it out I think.
    Quote Originally Posted by vmaxed View Post
    Coonasses boat had a berkely "r" intake. Yahh i took it out and sold it to one of Obamas relatives that buys scrap. It has a regular intake now prepared by yours truly.
