avgas or race fuel?
avgas or race fuel?
    Senior Member MR.Magoo's Avatar
    Default avgas or race fuel?
    ok guys trying to figure out if I am running the right fuel in my blower motor, been running avgas, seems to run right, but I want to make sure, I am running the best fuel for the motor, does avgas work at sea level? or does it need to be at high altitudes?, i'm sure you guys know the right answer.
    Mar 2010
    Clarksville, TN
    What compression and boost you running ??
    Senior Member Alter Ego's Avatar
    Jun 2010
    South Arkansas
    My motor is 13.1 most I spray is 250, I been running avgas since 2007. No issues, pistons valves guides etc always look good as new. You will have to run the jets a little fatter with 100LL. I pass an airport on the way hem from work, so if I know I'm goin to the lake I just carry a couple cans with me! I got the code to the gate, and pay at the pump!
    2011 Rouse Performance 19'
    WFL Crew
    WFO
    WFO is offline
    WFL Crew WFO's Avatar
    Nov 2010
    South Texas
    Yep that's all we run down here. In my 10.5-1 496ci, David currently runs it in his aspirated 605ci which is 14-1 and use to run it in his 525ci blower motor. like Alter Ego said easy to get and the price is right.
    WFLC
