TX19's
Results 1 to 14 of 28
TX19's
    Member 1980condor460's Avatar
    Newcastle
    Default TX19's
    Any major differences between the different molds? Youngblood, Condor, Jimmy Johnson, Sunkist, Warhawk?
    Apr 2010
    Rocklin, Calif.
    Well, Fleetimus lives up this way, with a condor....the cockpit is much wider than my cp
    Senior Member Alter Ego's Avatar
    Jun 2010
    South Arkansas
    There are only slight differences. Aside from straightened plugs, not much changed that wasn't intentional. The cp 19 kept the defined "crease" all the way around the deck rather than tapering off near the rear like most other 19' gull wings, the Warhawks have a little spoiler on the back rather than tapering down towards the rub rail, my rouse is a straightened splash of a kustom Kraft. Not sure if sunkist made any 19', but I do know they made 18' gull wings and some tunnels.
    if you saw differences between two 19' gull wings, it would only be because one is a narrow cockpit 19' and fleetimus' boat is a regular condor, nearly identical to the 19' of gone green. May be the way the interior is layed out may make it seem bigger inside. Put a tape measure to it and I doubt u find much difference if any.
    2011 Rouse Performance 19'
    WFL Crew
    classic hot boater Orange Peel's Avatar
    Mt. Island NC
    Default 19'
    I have a Sunkist 19' gullwing. Has a -P after the him?
    Its a straight side . I also have a 19' mantra gullwing its straight sides too.
    Never forget where you come from,no matter where you are going.
    Apr 2010
    Rocklin, Calif.
    Quote Originally Posted by Alter Ego View Post
    You could be right...Fleet has bucket seats..I have the cocktail seating, no mater Tons of driving Fun!!
    Jun 2010
    South Arkansas
    Quote Originally Posted by Orange Peel View Post
    I've never seen a straight sided 19'?
    WFL Crew
    Chantilly Va.
    And neither have I. I have a Sunkisst 18 Performer that measures 18'6". Tha HIN also ends with a "P".Name:  10653727_895746020436332_259336704872451299_n.jpg
    Colfax, Ca
    Buckets. I can measure if needed
    Is this real or the "Twilight Zone"?
    Apr 2010
    Rocklin, Calif.
    Buckets. I can<script id="gpt-impl-0.41068183081115633" src="http://partner.googleadservices.com/gpt/pubads_impl_75.js"></script> measure if needed
    The green one is 58" across
    Senior Member MR.Magoo's Avatar
    I have a 1982 eddies custom title says 18' measures at 18'6" runs the same as every other tx-19 that I have ever seen just slower, I also had a 1994 impact tx-19 and it ran the same, impact made like 3-4 tx-19's that I have found eddies custom may have made 2, mine is super light, with big hp it probably ran the numbers back in the day, now it only runs about 95.
    Mar 2010
    Clarksville, TN
    Quote Originally Posted by MR.Magoo View Post
    What does it weigh ?? What is considered "SUPER LIGHT"
    I'll let you know next time I take it apart, boat is paper thin every where bottom transom top
    Iuka, Mississippi 38852
    Were any or all of the Eddie`s Custom boats laid up by Greg High?
    To my knowledge Greg High never laid up a boat. He only rigged them.
