Hey guys... Will the extra weight (115 lbs I think) of a Bowtie block cause any performance issues in a 19'? The engine has or will have aluminum heads so I'm guessing it would be close to a standard all iron 454 long block but I wanted to ask anyway. The boat will have a jet-a-way and I know a lot of gullwings run them but I'm curious if other steps have to be taken to overcome the weight being moved forward or if it actually helps the overall performance. Assume the bottom of the boat is straight/flat.
