Need help on rail kit install
Results 1 to 13 of 13
    Senior Member boaterguy1's Avatar
    Feb 2010
    MUSKOGEE, OK
    Default Need help on rail kit install
    Is there anyone that can help guide me through the install of my rail kit?
    WFL Crew TINTDESIGNZ's Avatar
    East Texas
    Quote Originally Posted by boaterguy1 View Post
    is your pump installed?
    WFL CREW!
    http://www.performanceboats.com/cont...-magazine.html
    Everybody wants some...I want some too!
    Southwest corner AR
    I have some pics. that may help ya!
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    WT
    WFL Crew!!!
    Feb 2010
    MUSKOGEE, OK
    Quote Originally Posted by tintdesignz View Post
    not yet hopefully i can get it n by the first of next week then i can work on the rail kit
    Feb 2010
    MUSKOGEE, OK
    Quote Originally Posted by widetrack View Post
    i have some pics. That may help ya!
    [img][/img]
    [img][/img]
    [img][/img]
    [img][/img]
    thanks for the pics that will definatelly help!
    Feb 2010
    MUSKOGEE, OK
    Default spacers
    how thick r the spacers between the tubing and the rail and how far r the rails from the transom and setting the rails like this did u have to shim the front of ur motor to get the right angle on ur drive line
    Southwest corner AR
    I used 1/4" Alu. stock for a shim. That was just to take the rail dowm below the radi. of the stringer top edge! Level the rails with the stringers tops if you like! Then trim the plates to set the motor level!
    The placement for the rails needs to be checked with a block, plates, and driveline bolted to the block! You can get an idea where they should go then clamp them! CHECK AND RECHECK before any drilling is done!!! Center the rails to the motor plates and make sure they are even side to side up and down!
    I put small marks on the top edge of the stringers to locate the rails if the rails moved or got bumped! Good luck and if you need more info. just let me know!
    WT
    WFL Crew!!!
    Mar 2010
    Clarksville, TN
    bump
    Senior Member Alter Ego's Avatar
    Jun 2010
    South Arkansas
    Why'd u bump this? U need help?
    2011 Rouse Performance 19'
    WFL Crew
    Hey Josh. You goin to Muddy Bottoms.
    Jun 2010
    South Arkansas
    Quote Originally Posted by tigertooth View Post
    If I go it'll be without my boat. I'd like to see how bad muddy/dusty it is the first go round. I've been down there on an event weekend, and dumbasses are everywhere. Biggest deal breaker for me is mud, u know I'm a clean freak. By the end of the weekend the paved roads will be covered.
    I do think its an awesome facility, and is more or less the wheatland of mud riding, but I'm too scared to be a Ginny pig on this one. I'm sure some of my family will be there muddin.
    WFL Crew
    Come on man. Its in your backyard. They got grass to park us on. They wont let the 4 wheelers in our area. Im in. Matts in we fixen to get it on.
    Mar 2010
    Clarksville, TN
    Quote Originally Posted by Alter Ego View Post
    Just gettin ideas and didn't wonna search again if needed
