vaccume canister
Results 1 to 8 of 8
vaccume canister
    Senior Member german1's Avatar
    Mar 2011
    Default vaccume canister
    any of y'all run this? i didn't have 1 on my last setup but not sure if i need 1? any info would be appreciated . thanx Jeremy
    The Man cordog009's Avatar
    East Texas
    No vacuum advance here.
    1984 Youngblood TX-19 SOLD
    Mar 2011
    thanx cordog... i figured it all out, i do appreciate the reply. trying to get the float wet by this weekend, work out the bugs etc.
    Peoria, AZ
    It depends upon your application. For an all-out racing application a vacuum advance unit is not a plus as it can interfere with the timing curve but, if you are pulling skiers up from an idle it could prove beneficial to lose some timing at low RPM takeoffs. There was a valid reason the factories put them in our passenger cars for so many years.
    Senior Member hotbo's Avatar
    lake Ouachita AR
    there is no place for a vacum advance in a jet boat.
    WFLC
    2011 Performer SS
    built by Scott Seastrom.
    WFL Crew TINTDESIGNZ's Avatar
    East Texas
    x2
    WFL CREW!
    http://www.performanceboats.com/cont...-magazine.html
    Everybody wants some...I want some too!
    Southwest corner AR
    There is a few things to work out if using this dizzy! Go to your local parts house and see if they have a curve kit for it! Pull the rotor and replace the springs to the med. to light springs! The heavy springs are to much for a jet boat! Just my .02
    Or lock it out and do without it all together!
    WT
    WFL Crew!!!
    Mar 2011
    thanx fellas, going to do without it, i thought that was right but just wanted to make sure
