Steering Trouble
Results 1 to 14 of 15
Steering Trouble
    Mar 2010
    Clarksville, TN
    Default Steering Trouble
    Hey guys I wanted to see what yal thought I should do to get my steering from hanging up .. I have looked at everything and can't find why my steering is hanging . The only thing i done was coat it and that stuff is like .001 thick and put new nyliners in it .. Say straight is 6 0'clock and when it gets to 5 or 7 it wonts to stick .. Makes it a azz to drive, and i have sanded on the droop sum but I don't won't to go to far if it might be something else .. Just lokin for ideas Its not in the cable, cable aint even hooked up and it worked great last year ...
    WFL Crew TINTDESIGNZ's Avatar
    East Texas
    its got to be the coating or the new orings...
    WFL CREW!
    http://www.performanceboats.com/cont...-magazine.html
    Everybody wants some...I want some too!
    Senior Member coonass's Avatar
    Canyon Lake, TX
    give it time.... let it wear a little mine was hard at first but it gets better every weekend I go out
    WFLC
    Southwest corner AR
    Have you run the boat in the water? Jet pressure will loosen it up pretty quick! I sprayed some lube in mine to help till it wears some! It's worn now!
    WT
    WFL Crew!!!
    Mar 2010
    Clarksville, TN
    Its not tight, its stickin Does it under power also
    Might try to put the old nyliners in it and try it out ...
    Southwest corner AR
    Did you get the powder coating off the inside? And did you powder coat the Place Diverter?
    With it all together move it back and forth then pull the PD off and see where thr nyliners rub the droop! Work that area some more with your paper! If you did PC the PD then you need to take it down some!
    WT
    WFL Crew!!!
    Mar 2010
    Clarksville, TN
    It wasn't PC it was plated, this stuff is real thin, not like PC at all ... I'll slick it up sum more with sum sand paper and try it out .. You would think it would be tight throw all the movement but it aint, just in the turns
    Southwest corner AR
    I wonder how hot they have to cook the coating that they used?????? Maybe too hot?
    WT
    WFL Crew!!!
    Mar 2010
    Clarksville, TN
    I talked to Lindsey at Nitro and she said that they do bake it but not sure the temp and time it goes it .. A tech is gonna call me back with the info .. But I wouldn't think it would distort the droop, it hasn't anything else I done ...
    East Texas
    you can get ya a snoot now...and sell that melted droop...
    WFL CREW!
    Southwest corner AR
    Quote Originally Posted by TINTDESIGNZ View Post
    ROTFLMAO! I have a droop if you need one!
    WT
    WFL Crew!!!
    East Texas
    hang on to that one...i may need it.
    WFL CREW!
    Mar 2010
    Clarksville, TN
    I worked with it last night and I think it will come around , got the sticking out and still seems tight .. Hope i didn't go to far I'll find out today
    Thanks Guys
    Senior Member vmaxed's Avatar
    Sep 2010
    EAST LA (Lower Arkansas)
    Default Got 1
    I've got a Berk and a nozzle with a 3.125 bushing.
