Need help installing the saddle betweeen the pump and rideplate
    Senior Member boaterguy1's Avatar
    Feb 2010
    MUSKOGEE, OK
    Default Need help installing the saddle betweeen the pump and rideplate
    Need help installing the saddle betweeen the pump and rideplate can yall post sum pics and tell me where to drill please. Thanks scott
    Southwest corner AR
    Scott, what bowl do you have? Berkeley,Dominator there is a little difference and it does help to know! And you need to break out the stright edge or a dig.angle finder for best results!
    WT
    WFL Crew!!!
    Feb 2010
    MUSKOGEE, OK
    Quote Originally Posted by widetrack View Post
    scott, what bowl do you have? Berkeley,dominator there is a little difference and it does help to know! And you need to break out the stright edge or a dig.angle finder for best results!
    berkeley split bowl
    Southwest corner AR
    You can call me and I will walk you through it! To much typing!
    WT
    WFL Crew!!!
