TX19 build
Page 1 of 10 1 2 3 4 ... LastLast
Results 1 to 14 of 135
TX19 build
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    Default TX19 build
    Hey guys, instead of reposting I will start a thread here also and update. I posted a thread in the Jet Boat section of my build...just getting started.
    WFL Crew TINTDESIGNZ's Avatar
    East Texas
    Hey Led...where you from? Okie?
    WFL CREW!
    http://www.performanceboats.com/cont...-magazine.html
    Everybody wants some...I want some too!
    Led
    Led is offline
    Jul 2010
ID:	140800Click image for larger version.
ID:	140801Click image for larger version.
ID:	140802Click image for larger version.
ID:	140803Click image for larger version.
    fixed the usual cracks in the back corners, starting reinforcing the bulkhead and filling the dash to even out the hole locations.
    Southwest corner AR
    Led, that looks good what's next?
    WT
    WFL Crew!!!
    Led
    Led is offline
    Jul 2010
    tonight the plan is to get the dash filled, and the rest of the boat prepped for primer, then another night or two of......ding ding ding...sanding...then primer on Thursday or Friday. Alter Ego sent me some paint schemes and I will be toying some designs.
    East Texas
    nothin like sanding,sanding,sanding!!!! if you get bored...here's my build...Tintman's 1980 Youngblood TX19
    WFL CREW!
    Southwest corner AR
    Oh how I remember those nights and days! Good luck and keep us posted!
    WT
    WFL Crew!!!
    East Texas
    yeah me too! Fillin the dash was a beotch!
    WFL CREW!
    Led
    Led is offline
    Jul 2010
    I glassed in new wood behind the holes, but I am tired of cutting circles out of the glass, the funny thing is that i was able to make a pattern with one of my skoal cans. I will get it built up enough to put a few full length layers over the top.
    East Texas
    I replaced the wood behind mine too, and ground out the original holes and layed strips over the whole dash...its been 3 years and its stayed perfect... mine had alot of gauges at one time!
    WFL CREW!
    Led
    Led is offline
    Jul 2010
    the wood was in very bad shape around some of the gauges, which was the primary reason, but after further inspection the gauges were not even close to evenly spaced.
    Led
    Led is offline
    Jul 2010
    sorry its rated R...but i had to share, a friend at work decided to help out with a design idea.
    Attached Files Attached Files
    East Texas
    say it aint so!!!!!
    WFL CREW!
    Senior Member hotbo's Avatar
    lake Ouachita AR
    looks like something my ole man Drew
    WFLC
    2011 Performer SS
    built by Scott Seastrom.
